Underhood Liner: How many of you still have it?
My background is why you should stay out of Illinois....MARCUS! And I know you are not bringing up mothers. Do you even know your mother? She's that nasty *** drinking **** that's into beastiality right? You probably have a poodle for a father. He had to be copraphagous to have a POS like you!
I then cut that black rubber seal, the seal that attaches to the car but touches the hood when the hood is closed (I hope I am making sense). I only cut the middle part section / the curvy party above the TB area. I am keeping it, in case I want to put it back.
Anyway, I was at a red light and with the background of the red brake light on the car in front of me I could see more of the engine heat - heat wave - coming out from the hood vent and area above the TB.
I have this flat, long flashlight that I put on top of the TB, closed the hood and then turned off my garage light. In the dark, I could clearly see the light through the hood vent and from under the hood through the area I cut away above the TB.
I then taped some toilet paper in certian spots above the vent and underneath the hood on the outside, in front of the windshield, where I cut the black rubber seal above the TB. I then took my shop vac and reversed it (so it would blow air) and you could see the toilet paper moving -showing the air flow or how the heat wave could be allowed to escape the engine area through the hood vent and the area above the TB.
This was not very scientific, but I know the engine area is definitly allowing the engine heat to escape. I am going to now jet hot coat my surge tanks and valve covers, in hopes of further reducing engine heat. Also, do I know if any of this will increase performance? No, I do not, but does it make me happy and keep me busy with my mod hobby - yes.
2007 E63 AMG Mercedes Benz
RAAAAAWR, hiss hiss. ... good question. Do u think it may work- help NA 63? I think I'd enjoy a lil more motor thunder even tho I don't get the sc whine and boost noise like ur 55s. Since I don't have Hot sc sitting up top I'd prob just take whole liner off. Liner is prob more for noise control... Rubber seal may have some genuine use for AC not sucking hot air. +1 pics! Please
#35
I have the plastic piece below the hood vent removed.. No problems so far.. Thinking about removing the hood liner all together
#39
#40
1 Post
Viper SRT-10, CLS 55 AMG, 2012 Tacoma Off Road 4x4
I removed the rain shield under the hood vent last night and all I can say is make sure you use safety glasses! I almost lost an eye when the plastic screws POPPED out!! It actually cut my forehead bad enough to make it bleed... haha fail! So now I have removed hood liner, rubber gaskets, rain guard and the plastic intake tube flaps (behind grill). I have not turned on my radio in a few weeks now because the sweet music of the blower.
#44
SEARCH BUTTON > https://mbworld.org/forums/w211-amg/...nting-mod.html ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#49
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Really? Take off the plastic cover under the hood vent? Doesn't that help keep water out? If it'll make it sound nicer and still block water from coming into the engine bay area, I'll definitely remove it.
