Blocks :)
Sucks he broke an aftermarket piston. Won’t be too long before you’re getting after it again at the Texas Mile.
Detonation over long periods of time can cause damage like this as well, but you can usually tell if your engine has pinging for extended periods of time.
LS1, bored and stroked to 422, Procharger at 12psi. Heavily built automatic.Ended up selling the C5 before the build was complete. Kept shredding supercharger belts. We had it solid at about 710rwhp. Assuming about 18% loss, we were north of 850 at the crank.
Had 13 inch wide CCW classics. Couldn't hook up AT ALL.
Would break the tires loose. Easily. at 60mph.
Miss that car.
The cylinder wall has a lazer melt into the side of it, that matches the melted hole in the piston. Detonation works in very mysterious ways. couple valves on other holes had marks on them ..Nasty!!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Control heat, to include IAT, engine temp,and spark plug heat
Control Octane, to include reducing oil in the combustion possess
Control Timing
This the basic key factors in making your engine survive
Car had basic mods. Cooling, tune, pulley , 82TB and kleeman headers. About what 50% of the moders have on this forum.
www.ultimatepd.com
