Active Headlight Unavailable?
I'm assuming this means there's an issue with the active headlamp control system, but I'm not sure. Has anyone encounter this before, and what was the fix?
Might not be your issue, but it's free to try.
gonna read the error codes as it could also be a chaffed wire for which there is a MB tech doc to fix. otherwise i hear there is a motor available from a different mb model which is the same and is available seperately.
will report back on findings
no progress at present, i know its the right hand light motor, mbenznl has confirms its most likely the motor, so im on the hunt for either a used light unit or a broken Active light unit which i can use as spares. Luckily all the beams seem to be pointing correctly so the car is still drivable.
plugged in star and carried out the force left and right on the corning light function and the motor kind of made a loud wirring sound and came back to life, all works good again, passes all the tests and no more irritating dash error!, i will still stay on the hunt for a broken UK light in case it goes again. cant believe RHD and LHD units are different.
motor might have slipped a cog and got stuck and then unstuck, i think i got away lightly
cornering active lights are not a common option in the uk so quite hard to find a used one
thanks for all the comments and help so far tho!
