Damn supercharger pulley bolt won't come off.
Old Dec 1, 2011 | 12:36 AM
WHIRLINFIST's Avatar
2004 E55 AMG, 2016 Ram 1500 Crew Cab, 2016 S63 AMG, 2020 GLC 300
Originally Posted by dansamg
Mine was a SOB until I heated the crap out of the bolt with a torch, then it can off right away with a swivel bit and short extension.
That loctite takes a bit to melt
Exactly!! Dansamg is correct. You have use a torch. It has the red loctite on it. Heat it up really, really good and it will almost fall out. Just make sure you re-install it with Red loctite and torque it down to the proper specs. Let us know the outcome
Old Dec 1, 2011 | 01:17 AM
tbal's Avatar
Haters crazy
Heat is unnecessary and overkill. Hit it with a good impact gun, with a decent amount of psi it will come off easily...
Old Dec 1, 2011 | 01:57 AM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
650lb impact , 1/2 extension, 130psi or so, came off no problem. Someone must have been pissed with yours at the factory.....
Old Dec 1, 2011 | 07:11 AM
GT-ER's Avatar
2005 E55 AMG
LOL...
Did you heat yours?
What I wonder is, once you heat the loctite, do you have to re-heat it? I mean, does it go back to it's normal state when it cools down or does it loosen once it heats up and stay that way?
Old Dec 1, 2011 | 08:53 AM
GT-ER's Avatar
2005 E55 AMG
YES!!! Finally!! It took me fixing all the leaks and bypassing the regulator, using a shorter 6" extension, and modifying my compressor to reach 140psi ( normally regulated at 110psi ) and even then I had to hit it over and over again for about 30 minutes before it let loose. DAMNNNNN!
Thanks for all the tips guys. Crazy stuff I tell ya.
Old Dec 1, 2011 | 08:58 AM
GT-ER's Avatar
2005 E55 AMG
Also, I put the new bearing in the freezer and the pulley I'm going to be putting it in the oven. It should make my life easier.
Old Dec 5, 2011 | 06:20 PM
  #32
msheredy's Avatar
MB
So how did that little trick work for you? Did the bearing drop in without the help of a shop press?
Old Dec 5, 2011 | 11:00 PM
  #33
GT-ER's Avatar
2005 E55 AMG
It doesn't drop in per say....but all it took was slight tapping with a hammer and it went it very smoothly. No pounding or anything like that.
Old Dec 6, 2011 | 06:11 PM
  #34
msheredy's Avatar
MB
Nice! I've read about that trick before... Just didn't know anyone that has done it or how much it actually helped.
Old Dec 6, 2011 | 06:58 PM
  #35
grane's Avatar
GLK350, SL63 AMG
Metal hammer with a piece of wood in between or a rubber hammer?
Bearings are bearings.
Mobil jet oil checked ok?
Old Dec 6, 2011 | 07:10 PM
  #36
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
The heating/cooling thing works very well for press fit items. Used this trick many times for harmonic balancers over the years.
Old Dec 6, 2011 | 08:25 PM
  #37
GT-ER's Avatar
2005 E55 AMG
Metal hammer and nothing more, but I was tapping relatively light so no damage whatsoever.
Old Dec 9, 2011 | 01:27 PM
  #38
cwmateiuc's Avatar
2006 E55 AMG
I am having the same issue. Using a 6" impact extension with an impact socket on it. Using the best 1/2" gun IR makes! Heated it up, still didn't work. I'm trying penetrating lube now, hopefully that helps.
Old Dec 9, 2011 | 01:34 PM
  #39
xpl0sive's Avatar
CLS55 AMG
maybe try it with a swivel instead of the 6" extension. you need more torque
Old Dec 9, 2011 | 01:49 PM
  #40
cwmateiuc's Avatar
2006 E55 AMG
Tried that too... No luck.
Old Dec 9, 2011 | 02:10 PM
  #41
GT-ER's Avatar
2005 E55 AMG
I think cranking up the psi in my compressor is what finally did the trick.
Old Sep 16, 2023 | 04:52 PM
  #42
cannawhat's Avatar
E55 AMG
@GT-ER I assume you pulled out the radiator and fan in order to be able to use an impact? or is it easier to pull out the super charger? I tried to remove it by just using a breaker bar and a shallow socket on my E55 and it will not budge at all.
