Valve Gasket Leak?
Old Dec 4, 2011 | 01:17 PM
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Valve Gasket Leak?
Hey Guys,
So I replaced the gaskets 3 times and still leaks oil. Any ideas? I replaced them with OEM MB parts too. It usually leaks onto my headers and starts burning off that. I wiped the headers clean with Simple Green but still same result. Only leaks on Passenger side. Any Ideas? I posted pictures also.
Old Dec 4, 2011 | 01:34 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
did you reseal the breather on the cam cover?this also leaks, you need a gasket sealant for that.
Old Dec 4, 2011 | 01:35 PM
djrabbi's Avatar
Picture? No idea what your talking about lol
Old Dec 4, 2011 | 02:35 PM
WHTEVO's Avatar
07' SL65, 04' E55, 03' Evo8, 08' GSXR, DSM's...
The baffles/ breathers are the parts on top of the valve covers that have bolts through them. You need to remove the bolts, remove the breathers and clean, then reseal and install with RTV sealant.
If you look closely at your first pic, its the parts on the top left. Do both.
Good luck.
Aaron
Old Dec 4, 2011 | 04:33 PM
marko62ss's Avatar
04 E55 Stock "for now"
Little bit of a noob question but, did anyone ever modify there valve covers with a breather/filter?
I figured that would solve some of the leaks that our cars are subjected to.
Old Dec 4, 2011 | 05:43 PM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
^ This is your problem/solution ^
Old Dec 4, 2011 | 07:22 PM
djrabbi's Avatar
the covers in the second picture with the torx screw in them?
Old Dec 4, 2011 | 08:05 PM
bobgodd's Avatar
2004 E55
Also, I've tried replaced the gasket a couple times as well and still have leaks. it wouldn't hurt to use a sealant in addition to the gasket.
Old Dec 4, 2011 | 10:18 PM
djrabbi's Avatar
anyone have a picture or DIY on breather covers?
Old Dec 4, 2011 | 11:00 PM
GT-ER's Avatar
2005 E55 AMG
Good luck.
Aaron
THIS!
Old Dec 5, 2011 | 07:01 AM
slownrusty's Avatar
'06 E55 K2
I went through this ordeal recently.
Couple of pointers:
1) Reseal the breahter covers with Permatex Black \ Ultra Grey as already mentioned and yes this is the small cover towards the rear of the engine (on the right side) that has three small torx fasteners.
2) The actual valve cover gaskets have a very specific tightening sequence starting from the top middle, then bottom middle and working left then right (as you face the engine) and work towards the extreme ends of the valve cover.
3) Do not over tighten the valve cover on the head.
4) Apply the valve cover "dry" no sealer or Permatex required.
5) Make sure all mating surface are clean and free of debris and particles.
6) Be patient.
Good luck.
Old Dec 5, 2011 | 08:41 AM
djrabbi's Avatar
Valve covers were done by Mercedes, everytime I call and tell them. They want to charge me more and re-do it yet again. I spent like $500 already on just valve gaskets for past year. I still don't see the breather covers? Maybe someone can point an arrow? I am a newb!
Old Dec 5, 2011 | 09:22 AM
WHTEVO's Avatar
/\ I explained what needed to happen. It is pretty straight forward to do. Not sure why you are mentioning the second picture when i said it is in the top left of the first pic you posted. If you take a few minutes and go look at the top of your valve covers, you will see the parts that are bolted to the tops of them. Good luck.
If you search, you'll find a lengthy write-up on it all.
Aaron
Old Dec 5, 2011 | 09:23 AM
djrabbi's Avatar
Oh just those 5 bolts?
Old Dec 5, 2011 | 11:29 AM
Alps's Avatar
dude, tbal done a good thread search for "valve gasket leak", everything you need is in there!
the browser at work is cut down and i cant copy\paste links
