Pulley Weight Comparision - ASP 180, ASP 190, Redtooth Racing Variable Size
Rating: Thread Rating: 10 votes, 5.00 average.
Old Dec 16, 2011 | 09:37 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I purchased a Redtooth Racing crank pulley yesterday. The Kit come with the following. I plan to install it today. Torqueing specs are same as stock crank pulley.
1. Crank Pulley with outer ring as per your choice. I got a 190mm. From what i understand custom and additional ring sizes are avaliable.
2. Lightweight water pump pulley
3. OEM AMG Crank bolt
4. Gates Belt
Below is a comparision on the weight. ENJOY my friends!!!
ASP 180 weighs in at 14.5LBS
ASP 190 weighs in at 15LBS
Redtooth Racing Pulley with 190mm ring weighs in at 10.5LBS (Same as Stock Pulley)
Old Dec 16, 2011 | 09:49 AM
shardul's Avatar
QUESTION OF THE DAY FOR ALL THE NUMBER CRUNCHERS!!!
4.5lbs to 5lbs off the crank equates to how much RWHP?
Old Dec 16, 2011 | 09:55 AM
Bramage's Avatar
F-250
I just pulled off my 180 ASP pulley and it weighed 13.5LB. The new ASP 190 weighed 13.1lb. (Digital bathroom scale)
I was not looking for or expecting a weight savings, both are steel. The holes around the circumference of the pulley are the same size, just more of them on the 190. I was pleasantly surprised
Old Dec 16, 2011 | 10:03 AM
chawkins2001's Avatar
2006 E55 AMG
Even 4lbs of rotational mass is a ton of savings. I bet it frees up at least 10rwhp or so.
Old Dec 16, 2011 | 10:09 AM
ahmad0658's Avatar
Brabus K8 E55 05
Shardul, How much did it cost you?
Old Dec 16, 2011 | 10:10 AM
JoshM813's Avatar
2005 E55 AMG
Its about 10-15 whp across the whole power band
Old Dec 16, 2011 | 11:38 AM
KLR CLS's Avatar
CLS63 PP
how do these install? can you use the factory style crank pulley holder or do you need to lock the flywheel?
Old Dec 16, 2011 | 11:46 AM
shardul's Avatar
lock form flywheel or make a tool like this (courtesy Exotic-Metal55)
Old Dec 16, 2011 | 12:04 PM
GregMB's Avatar
Shardul,
Do you happen to know what the O.D. & wall thickness is for that keyed portion of the tool??
I might already have tubing scrap that's the right size in my workshop.
-G
Old Dec 16, 2011 | 03:03 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Not sure how some got to 10-15 hps with this but the power freed up will be dependent on the gear. And I'm saying freed up for a reason since there is truly no power gains to be had. Its just that we all mostly do pulls on an inertia dyno and this changes inertia. On an engine brake dyno, this would show nothing. In first gear because the engine accelerates the fastest you would see the most benefit and nearly nothing in 5th. Its no different than changing a flywheel except the diameter is alot smaller so the effect is not as significant. My guess is that on a 3rd gear pull it would equate to a few hp's but not much. I can do the math but I would need some details from you Shards on the dimensions of the pulley so i could get a proper moment of inertia. If the full 10lbs is all on the outside edge vs directly in the center, that makes a big difference too. Send over the details and I'll put a spreadsheet together.
Old Dec 16, 2011 | 04:39 PM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
You are absolutely correct and while you cannot change the laws of physics as H.G said "it's the little things..." and all the little things add up.
Old Dec 16, 2011 | 10:34 PM
adianaty's Avatar
That's why when I upgrade to a 190 it's going to be one of these for sure.
Another great innovation from the Houston crew. Bravo and keep them coming!
Old Dec 17, 2011 | 07:49 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I was trying to run some moments as well. Take 190mm at 15lbs and 190mm at 10.5lbs. Both have steel hubs but one ring is steel and the other is aluminum. Granted, we do not know what the weight is on the outer edges of the 190mm but it is alum. VS steel .. So how much inertia is added at 6000 rpm? 4.5 lbs is added to the stock hub on the pulleys that weigh 15lbs.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 26, 2012 | 09:57 PM
PLATINUM SPONSOR
2003 CL55
Did you use the tool or hold the flywheel?
__________________
www.ultimatepd.com
Old Jan 29, 2012 | 08:23 AM
lowprofile's Avatar
E55
4. Gates Belt
Are you sure the first photo is a 180mm? It looks way smaller than the 190 in photo 2.
I've weighed the ASP and stock pulleys too, but on a postage scale. The ASP pulleys I have measured come in around 13 and a half pounds depending on overall size. Stock was approx 10 and a half.
Anyone notice the botched install on the first pulley? Yikes!
Just wanted to add, photos and weights aside, I believe you have a great product on your hands.
Old Jan 29, 2012 | 11:17 AM
shardul's Avatar
Yes it is a 180mm. Btw it is the one that someone sold to hammerdown
Old Jan 29, 2012 | 10:11 PM
lowprofile's Avatar
E55
WOW! Hard to believe someone would try to pass that off.
Old Jan 29, 2012 | 11:49 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
I thought that looked familiar, just written off as a loss
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
