super cold weather.no filter and bam map sensor code again.
car was running soooo clutch last night,had the thing get wheel hop in second at like 50 mph and just about as Im going to run a car I get this weird mushy pedal feeling and the car feels like the belt is slipping(I thought the belt poped off) so after a scan I got the dreded max performance limit on the map sensor code again.
reset ecu and car is a beast again.
Im getting high temps and its really cold out here.
Like 20-30 above ambient in 29d weather.
I just checked the pump and its working.Anyone have a quick spilt cooling list I need?Im going to the store now and might as well get that out the way
I don't get it, I changed the sensor and situation continue, It only happen when I drive on steady speed on highway for about 20 - 30 mile with speed close to 80 MPH.
I think 20-30 above ambient when it is that cold is good. I run about 12-18 over ambient when it is 70-90, but on cold mornings (39-45) I run around 25-30 over ambient. I attribute that to the engine bay being much warmer than ambient, and the extra heat simply being leeched as it goes through the intake.
Splitting the system would help, or minimally not hurt.
When I did mine:
- 6' of 5/8" heater hose
- 3/4" to 5/8" splice
- 3/4" Splice
- 5/8" T
- Reservoir (BMW)
I used the write up one here using a BMW PS reservoir, and it worked as advertised.
Searched, and can not find the friggin DIY.
Oh, here it is:
https://mbworld.org/forums/w211-amg/213966-diy-heat-exchanger-prep.html
In the DIY, there is a single connection from res to the circuit.
I took a 3/8" hose from the bleed point (metal hose next to SC) and ran that to the smaller connection on the resevoir. This allows for auto bleeding of the system.
Yeah, that code would show up sometimes regardless of temperature whether it is hot or cold, tonight it was cold while coming back from Dubai and got the same situation temperature was around 18 - 20 Deg C (64 - 68 Deg F)
Starting my next phase of cooling upgrades next week when everything arrives. Then move on to fender tanks which I have already sketched out. If that does not do it, Killer Chiller it is. It was 52 out the other evening and my IAT went straight to 134!
