almost done the ultimate split cooling setup(not selling anything lol) just a teaser
#51
If you want I will sell you all my stuff,I promissed I wouldnt turn my e55 into a modded freak like my m3 and I took a bunch off stuff off.Im even going to throw a 168 pulley back on after I see what it does at the dragway when it opens in a few months.
an oem one would looks nice and it could easily be done but Im not sure how much room you got for one.
you could put it where tbal put his but you would loose the cabin filter.
#53
Break Horsepower record - Then overclock your CPU
WIN WIN
#54
E55 AMG W211 - sold, CLS 500 C219, E63S AMG W212
Skratch did you already install the 7series tank?
Is there enough room? I think we can use an 3/4'' hose right???
Maybe you show us an pic :-)
#58
Received 1,488 Likes
This place is a joke.
I have been thinking about a way to split my system, at minimal cost, and not loosing any trunk space or the cabin filter...Looking at my car up on the lift, there is a huge area behind the rear bumper...I was thinking instead of a tank back there, why not another heat exchanger....instead of a tank the heat exchanger back there would get some airflow, and coupled with the lines running to the front the volume should be about right....I would make the lines aluminium with hoses just for the connections, using the aluminium lines as yet another heatsink to cool the fluid..And also I can add another stock pump back there and power it from the rear SAM (fusebox) just like the front pump...Put a resevoir higher up under the hood for filing and bleeding...any reason this wouldn't work? Another idea is making a tank for inside the drivers front fender, and just relocating the alarm siren...Any thoughts? One of my goals is to go faster while looking stock outside and under the hood....
#60
Sorry guys I never really went 100% with this and have my car listed for sale when I gave up.
I installed the heat exchanger in my computer and running 2 blocks with a 300 watt pelt in between the loop.
![](https://sphotos-b.xx.fbcdn.net/hphotos-prn1/c67.0.403.403/p403x403/547338_10151163792825435_1281707599_n.jpg)
#61
