Official Suvneer E63 Front Conversion Thread
Old Mar 30, 2012 | 03:34 PM
  #201
OXOJE55's Avatar
///AMG
PM'd
Originally Posted by lm7
I have the adhesive brackets everyone has been using as I ended up not using them on my conversion will sell for $110 shipped.
Old Mar 30, 2012 | 07:44 PM
  #202
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I've got one coming, I can't wait to get it on with a new set of wheels. Far too plain looking now!
Old Mar 30, 2012 | 08:11 PM
  #203
lm7's Avatar
lm7
2003 E55
Some crappy cell shots will get some updated later this week.
Gary is awesome to deal with and will take care of you, very responsive great CS.
the kit itself is great out of the box but would reccomend some finishing from your bodyshop of choice.
I switched out the lower mesh for an oem piece as I preferrd the oem look vs what comes with the kit. I also went ahead an wrapped the chrome fog light rings in black vinyl.
Old Mar 30, 2012 | 08:41 PM
  #204
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
How much did you pay for bodyshop ? any complication for the parking sensors ? are you in Socal ?
Old Mar 31, 2012 | 12:53 AM
  #205
lm7's Avatar
lm7
2003 E55
hard to say since i got some other work done at the same time. with the sensors I opted to epoxy on the brackets from my previous bumper with some minimal fab. not in so cal, in the sf bay area.
Old Mar 31, 2012 | 02:50 AM
  #206
ebtek's Avatar
2005 E55
Looks clean
Old Mar 31, 2012 | 12:57 PM
  #207
lm7's Avatar
lm7
2003 E55
Originally Posted by ebtek
Looks clean
Thanks man. good to meet you today.
Old Apr 1, 2012 | 12:39 AM
  #208
ebtek's Avatar
2005 E55
Good meeting you too bro. Thanks again for the parts.
Old Apr 1, 2012 | 05:32 PM
  #209
OXOJE55's Avatar
///AMG
Which lower mesh did you use and how much was it?
Please part number for bottom grill
Old Apr 3, 2012 | 01:53 PM
  #210
I'm impressed! I ordered this bumper late Wednesday afternoon and Gary sends me a tracking number 30 minutes later. The bumper made the trip from Los Angeles to Orlando in six days and everything looks fantastic.
Old Apr 3, 2012 | 03:33 PM
  #211
lm7's Avatar
lm7
2003 E55
211-885-13-53 Center Mesh
Old Apr 6, 2012 | 06:52 PM
  #212
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I have a question about the two pieces of foam, one on each corner of the bumper. Do these not get transferred over?
I haven't heard anyone say something about purchasing different ones or just not running them. I dropped the bumper off to be painted which was $332 then went to swapping but those two pieces of foam don't seem to fit on the new bumper insides.
I bought the 3 oem E63 plastic pieces that were mentioned and part numbers listed earlier in the thread to go inside and it seems like the pieces of foam have a part to them that doesn't allow them to fit all the way in and get locked in to the bumper on the corners.
I assume that most everyone had a body shop put the bumper on for them so they may not even know about this, but if anyone does know what you did about this I would appreciate it. I am about to just put the bumper on without them but it seems like it would make the bumper fit better since the back side of those foam pieces rest against the metal bumper of the car that is beind this new bumper cover.
Here is a quick pic of the bumper ready to go on before I took the stock bumper off.
Old Apr 6, 2012 | 07:21 PM
  #213
pullejo's Avatar
'12 E63, E55(sold), C32 (sold), '65 Skylark GS 445 convertible, '12 ML350
I bought the OEM E63 foam as well and we used them in my install. Search for my posts with the parts.com list if you want them. Many others trimmed their pieces I believe. I bought the reinforcements: https://mbworld.org/forums/4986032-post147.html
Old Apr 6, 2012 | 07:26 PM
  #214
urbamworm's Avatar
Cool thanks, "Energy absorber" I guess is the term of what I need. I guess I can try trimming it first to make it fit and if not head on down to the dealer to see if they may have them in stock. Sucks I was just there earlier to buy a new center cap which I was surprised was only $18, didn't get raped bad at all on that part.
Old Apr 6, 2012 | 08:19 PM
  #215
phampau's Avatar
E55
I didn't use the outer foam but trimmed the middle one to fit in the center of the bumper
Old Apr 6, 2012 | 10:10 PM
  #216
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
How did you attach the chrome corner impact strips? Also how about the fogs?
Old Apr 6, 2012 | 11:35 PM
  #217
BrianS's Avatar
2004 E55 AMG
The corner strips just snap right in. Press slowly and work your way around. You need to get the clips to slide on over the holes and screws to hold the fogs in.
Old Apr 6, 2012 | 11:39 PM
  #218
BrianS's Avatar
2004 E55 AMG
I'm installing my bumper myself. What you need to do is remove the center reinforcement then drop in the outer foam pieces. Once those are in reinstall the center reinforcement plastic and drop the center foam piece into that.
Old Apr 7, 2012 | 10:13 AM
  #219
urbamworm's Avatar
The E55 foam pieces don't fit properly, the shape of them on the front side hits the inside of the bumper not allowing for the outter corner to pop in place beind that little "hook" sticking out from the black plastic bumper support. I actually shaved off a few of the parts of foam that protrude out and got it to sort of stay in place but when I went to put the bumper on it wouldn't slide all the way on the car correctly. I just said screw it and took it back of swapping the E55 bumper back on and am going to go get the correct foam pieces fo it to fit right. I don't feel like cutting stuff up more to try and rig it.
As for getting those corner foam pieces on though, all I did was slide the inside edge under that center suport and then with a little work got the outter corner behind that little lip/hook to hold the outside edge of the foam in place.
Regarding an earlier post, I just bought some nuts and bolts with lock washers from Home Depot to bolt the fog lights in place and the grills.
Old Apr 7, 2012 | 08:34 PM
  #220
urbamworm's Avatar
Ok, I played hell getting this bumper on, but finally got it done. I at first couldn't figure out why it wouldn't go all the way on. I trimmed the foam pieces some more and tried fitting again but still no go. I then got under the car and realixed the two connection points in the center of the bumper (the actual oem e63 plastic center piece I ordered that fits inside bumper) was hitting the Eurocharged heat exchanger not letting the bumper go back any farther. These were cut off on the original bumper to allow it to fit, so I simply cut those off all the way flush and then the bumper went on. A little fighting to get it lined up as good as I could and then a few bolts tightened and I was finished. Happy with the end product.
Old Apr 7, 2012 | 08:39 PM
  #221
FromM3toE55's Avatar
2003 E55 AMG
looks great!
Old Apr 8, 2012 | 08:49 AM
  #222
phampau's Avatar
E55
looks great!
Old Apr 15, 2012 | 12:14 AM
  #223
AKnight55's Avatar
Old Apr 15, 2012 | 12:17 AM
  #224
dannish23's Avatar
'07 e63 AMG, '06 e320 CDI, '07 ML350 4Matic, '18 Gls450, '12 cls550
paint that badge on your grill and it will look KILLER
Old Apr 15, 2012 | 06:56 PM
  #225
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
beautiful e63 front ends ... very jealous
You have already rated this thread Rating: Thread Rating: 14 votes, 5.00 average.
