RIP My E55
Rating: Thread Rating: 9 votes, 5.00 average.
Old 12-25-2011, 11:08 PM
  #151
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Car has always held the RPMs when letting off the throttle, it does hang a bit long IMO and at times I change it to C which makes it shift up.
Old 12-26-2011, 03:18 AM
  #152
ASP
ASP's Avatar
2016 Freightliner "daily driver"
Originally Posted by AKnight55
If you part out, which I hope isnt true and you get everything sorted out and slap that weistech upgraded blower on, I call dibs on the wheels..
Got a set if you're interested
  #153
ASP
ASP's Avatar
I've had the Tcu tuned in my car for at least three months and I WOT everyday I drive it! There are no issues what so ever, I have also bounced of my rev limiter in M when I was drag racing at 6800rpm and again I have no Issues. Will find out tomorrow
Old 12-26-2011, 07:10 AM
  #154
GT-ER's Avatar
2005 E55 AMG
Mine does the same thing. All you need to do is tap the upshift button in the steering wheel and it'll upshift. No need to change to C.
Old 12-26-2011, 07:35 AM
  #155
BRABUS786's Avatar
Stage 3 63
number 8 melted!
That wat happened to mine!
Acid
Old 12-26-2011, 08:07 AM
  #156
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Originally Posted by e55amgrocket
I'm not saying this isn't a rpm problem but I have a set of heads getting redone now and the guy that is doing them said that with these low lift camshafts (.417/.418 lift) and the double springs we have stock it's not going to float the valves at 7000 rpm. These heads are built extremely well from the factory and that's why finding a good port job took exotic-55 a year because of the low lift cams we have to begin with. We're not dealing with huge lift cams that can cause the valve to get out of control with these cars if anything dosent like the high rpm in these engines it would be the pistons/bottom end. I'm wiling to be this was a fuel issue (lack of fuel). My car on stock injectors were maxed out so fast with only a 175 pulley and a few other things it was crazy. These engines were made to run rich and don't last at high rpm and lean
Gas is always cheaper than valves (and pistons)
Old 12-26-2011, 09:12 AM
  #157
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
Sorry to hear about your engine. Curious to hear what your tech discovers post inspection.
I've cracked piston #8 twice on two modded AMG motors. I too believe its cause was fuel related AND inferior stock cast piston.
I've recently installed a set of forged MAHLE pistons (same pistons found in Renntech's fastest SLR) and the quality is second to none. My JE forged pistons cost the same, but don't even compare.
The 3 most important parts these motors need prior to any other modifications:
-Larger injectors (tuned obviously)
-TTM fuel rail
-MAHLE Forged Pistons
Correct the manufacturers weak spots and sleep well at night!
  #158
RaceHorse's Avatar
CL65
Originally Posted by BBBSS
Thats not what he was referring to....I have noticed the exact samething and apparently its common with other TCUs. I understand I have a different car but I have noticed the same with my car. With just an ECU I was able to do a WOT pull and when the R's were up I was able to take the load off the engine by hitting the "+" or upshift steering wheel control. That would allow the rpms to drop while in DRIVE and Sport mode. Now with the TCU same setup in DRIVE when hitting the "+" upshift button after WOT there is no response and its only after the normal wait time that the rpms drop off.
Sorry to go off topic a bit, and very sorry to hear of the motor problems. Hopefully things get sorted out quickly and you have an idea later today. I Dont want to think of it as an RIP, hopefully a little surgery and PT and you will be back in the game.
Old 12-26-2011, 11:11 AM
  #159
beauphus's Avatar
CLS55 & CL CK60
i think this never actually happened and bruce is staging fake #8 problems so he can sell more of his fuel rail. buy stock in TTM!!!
sorry to hear about your motor. each time you blow an engine its a chance to bring it back from the dead better than whence it came....
Old 12-26-2011, 11:32 AM
  #160
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
19" F14s in Gunmetal?
  #161
Former Vendor of MBWorld
TTMotorsports's Avatar
Whatever we're tuning!
I would never do such a thing Aaron(you know that but there is an IPO coming shortly) but all of these heavily modified M113k owners that think that if they just put higher flowing injectors in their stock rail is going to make the problem go away are 100% WRONG!! The members that insist that the TTM FUEL RAIL along with the TTM INJECTORS isn't necessary are misleading all members that believes that to be true. 10.59@131 and I am sure that TTM Fueling Kit equipped E55 has full compression in ALL CYLINDERS!!!
The 2 most active tuners on MB World recommend the TTM Fueling kit to all of their heavily modified clients. They are also the 2 tuners that found 25-30rwhp after just ADDING THE TTM FUELING KIT!(Thank you Jeremy and Jerry)
One member who claims to be making 530+rwhp still has stock injectors too and is the biggest culprits spewing misleading information to the entire MB World community. A couple of 3-4 gear runs in cold weather and...........you guys know the rest! RIP. The weather in the NE is great for DA but bad for unequipped cars. I wouldn't hold my breath!
Old 12-26-2011, 12:10 PM
  #162
e55amgrocket's Avatar
Dirt Scooters
Whats the price on the ttm fuel rail?
Old 12-26-2011, 12:14 PM
  #163
Roverron's Avatar
ML63
Hey get in line on that fuel rail.
Old 12-26-2011, 12:20 PM
  #164
AKnight55's Avatar
Would like to know price on rail and injectors as well please
Old 12-26-2011, 12:41 PM
  #165
TheVazha's Avatar
W212 E63
I'll bite...What is the price on he fuel rail? Also, anyone in LA know where I can get it rigged?
Old 12-26-2011, 12:50 PM
  #166
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Originally Posted by DVC
You have a good attitude John. Really hope it's minor.
I hope its minor too bro!
-TTM fuel rail
Thanks for the support man. I will take this into consideration if I need to fully rebuild my motor.
Old 12-26-2011, 12:52 PM
  #167
Johncy2000's Avatar
I will be recieving my fuel rail within the next couple weeks. If anyone is interested and doesn't want to wait for the rail to be done, I will have mine available for sale at full price plus shipping.
Old 12-26-2011, 01:14 PM
  #168
lm7
lm7's Avatar
2003 E55
Johncy what is full price?
Old 12-26-2011, 01:26 PM
  #169
Johncy2000's Avatar
PM sent.
Old 12-26-2011, 01:32 PM
  #170
320 dreamer's Avatar
2003 porsche 996 turbo
so you will rebuild if needed and im guessing reinstall the same mods as before? selling the fuel rail that is on backorder sounds like a firm solid game plan
  #171
jddumas's Avatar
2006 E55 & 2009 Audi S5
Would like to know as well bro. Went to the website and couldn't find.
Good luck on your motor.
Old 12-26-2011, 01:37 PM
  #172
Johncy2000's Avatar
I will rebuild but I don't think I will mod my car anymore. I want to bring it back to stock specs I think. Well see how the damage is today.
Old 12-26-2011, 02:07 PM
  #173
Robert AMG's Avatar
Cls63 & C32
Hope to be only a melted piston not also a cylinder wall like this one in the picture:
Old 12-26-2011, 02:09 PM
  #174
Johncy2000's Avatar
Attachment 224960
Your scaring me here bro.
Old 12-26-2011, 02:20 PM
  #175
Robert AMG's Avatar
Cls63 & C32
don't be scared it's a 180mm pulley with 100 shot nitrous!
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: RIP My E55
