Need Part Number for Harmon Kardon Center Speaker
Old Jan 2, 2012 | 02:27 AM
CityOfAngels's Avatar
2006 E55 AMG
Does anyone have a part # of the Harmon/Kardon center dash speaker for a 2006 E55?
Edit: Is this correct? 1698201802
Old Jan 2, 2012 | 05:50 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I'm curious what they charge for these. I know domestic cars are known for having highly priced stock replacement speakers. You may want to call a respectable local car audio shop and inquire about a possible direct replacement of higher quality. You can probably buy a much higher quality speaker for what your gonna find the stock one.
Old Jan 4, 2012 | 12:22 AM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
I was quoted $280 at a dealer but ended up finding it online for $67. The removal and install is very easy.
Old Jan 4, 2012 | 01:42 AM
christitsworthb's Avatar
bmw
Old Jan 4, 2012 | 02:42 AM
BBBSS's Avatar
Old Jan 4, 2012 | 02:56 AM
2006 E55 AMG
I ordered mine for $80 shipped. Do you know how to install it? How do I remove the speaker cover grill thing?
Old Jan 4, 2012 | 03:36 AM
jayjmuir's Avatar
Yeap, it is really easy. My car is a MY2007 though, so I think it is slightly different. For mine, you take a tiny screwdriver and pry up the mesh cover from the 11 and 1 o'clock positions.
For yours, the cover should have slits instead of a mesh and I believe there are two little clips in the 6 and 5 o'clock positions inside the bottom slit (nearest a/c controls). You need to look down into the slits with a flashlight and you should see them. Once you release the clips, the cover should come off. You then have to use a torque bit screw driver to remove the two screws holding the speaker in. Once removed, pull the speaker up and out and detach the connected cable. Repeat in reverse to install the new one.
Old Jan 4, 2012 | 07:24 AM
BBBSS's Avatar
When you put it in can you note how many wires run to the speaker? Wondering if its some kinda crazy setup or just a couple wires or what. I wasn't too happy with what I heard turning up the stock system and was wondering about possible upgrades.
Old Jan 12, 2012 | 08:11 PM
2006 E55 AMG
I have a 2006 which I think has the same speaker grills as the 2007. Do you have a pic of the specific screw driver (size) needed?
Old Jan 12, 2012 | 09:41 PM
grantwoodtx's Avatar
GLE 63S
Just pull the grill "thing" off and slap it in there.
Old Oct 22, 2012 | 08:13 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
This is very brief for what it just took me to do.
There is a tab at 12 o'clock, get a piece of plastic shoved in about 1/2 to 3/4 inch.
Now "all you gotta do is"...
get the top edge of the grill pulled up a little so you can pry up with your fingers.
Pull hard, the 4 spring clips are not easy and you need to apply force that would make you think you are going to break something. When they release it pops up and then pull to the wind shield to remove.
I still did a little scuffing of the dash material which I hope goes away with some TLC.
The speaker (A169 820 18 02) from Logic 7 clearly had failing adhesive between the frame and sound cone. Otherwise all flexible materials are like new. I am tempted to fix the speaker itself.
(now performing closer inspection)
Nope, can not fix it. The lower material has also sperated from the frame. Gonna go here and buy a new one for $78.75. This part number is used in many locations across multiple platforms.
I will post a more formal DIY later as a new thread. At least the offending buzzing is gone...
Old Oct 22, 2012 | 11:11 PM
CKCarbonImports's Avatar
Former Vendor of MBWorld
2004 E55 AMG
I have the same buzzing/vibrating/echoing which annoys me to death!!! I am gonna go take mine apart right now
Old Oct 20, 2017 | 04:34 PM
btv94's Avatar
2007 E350 RWD SP1 (M211.056/E272.964)
5 years later, is your center speak from oe discount parts still working good?
Just order one today $102.75
Old Oct 24, 2017 | 03:24 PM
kenneyd's Avatar
poop
I took mine out due to rattles, and glued the crap out of it. works great now!
Old Oct 24, 2017 | 03:42 PM
btv94's Avatar
Didn't work for me after gluing around the side to metal frame, as Jon2007E63P30 states the lower portion has also separated from the rubber part and end up buying new one.
