**** New Mercedes 1/4 Mile Record: The First Mercedes In The 9s - RENNtech-SLR ****
This record was run in April heat Florida, Not Winter time by any means NOR fantastic DA etc..60' 1.626
330 4.412
1/8 6.682
MPH 108.99
1000 8.629
1/4 10.274
MPH 137.46
__________________
RENNtech CL65 - 10.27 @ 137.46 mph video http://www.roadtesttv.com/world-reco...z-road-test-tv
He'd need 660-700 RWHP NOT crank HP, & or 3800 stall converter, or change final drive ratio (gearing) to 4:11's & or modded to ALL wheel drive
I believe his highest RWHP Dyno's showed @ best 440-RWHP..http://www.dragtimes.com/Mercedes-Be...lip-14621.html
EDIT: I looked it up on Dragtimes weight w/driver 4450 lbs & 420 rwhp, on run in link near identical 1/4 ET but 60' 1.87 that makes much, much more sense.. Not trying to put you on BLAST Juicee, but that 60' in ur siggy is obviously an error from improper track lights, IE all your other 60's @ comparable ET's & Traps are ALL 1.80-1.9x
http://www.wallaceracing.com/calc60hp.php Calculator-Enter vehicle curb weight inc driver, & 60' ran. It'll then convert it to how much REAR WHEEL HP you'd need
to achieve that particular 60' (obviously not EXACT science but VERY fair/true estimate)
Tom
The Renntech CLS already ripped off a 10.98 @ almost 130
For a 4200 lb (being conservative as juice weighs 200+lbs so incl all weight reduction 4200 lb race weight is more than fair)
I believe his highest RWHP Dyno's showed @ best 440-475 RWHP..http://www.wallaceracing.com/calc60hp.php Calculator-Enter vehicle curb weight inc driver, & 60' ran. It'll then convert it to how much REAR WHEEL HP you'd need to achieve that particular 60' (obviously not EXACT science but VERY fair/true estimate)
4 tenths improvement on 60' = 8 tenths in1/4 ET..http://www.dragtimes.com/Mercedes-Be...lip-19104.html
Though that's where I plan on running my SL soon... I think the track owners reported fixing faulty timing equipment, though recent data still shows Sac Traps higher than national averages. So Cal guys NEVER see negative- 1000-2000 DA @ Sea Level, like the Eastcoast wonder tracks MIR/ATCO/etc They also have phenominal track prep vs tracks like Sacramento, plenty of peeps smack wall @ 1/8th... Maybe the F'd up timing equipment is the ONLY way we So Cal'ies can get comparable ET's to Eastcoast
http://www.dragtimes.com/da-density-altitude-calculator.php?temperature=46.0&rh=56&altset=30.27 &elevation=30&track=132&month=1&day=8&year=2012&ti me=9:53%20AM
or custom pretzle machine like Jody
Few other +'s from CF shaft (tho I'm sure you already kno this stuf)
Weight is less than half Steel or Chromolly, IE my quote is 6-8 lbs vs 18 lbs
Allows your rpm's to spin far faster & higher
Documented to knock 2 tenths off 60'
Not to mention more Unsprung weight loss & drivetrain HP/TQ loss minimized
Post #23 from the owners mouth himself. The exhaust was changed. Also cf body kit and 50k suspension
Oh and they ran without a trunk
More mods coming!
JESUS CHRIST! The CL65 is a heavier than a 747, even a tank is lighter, the V12 alone without the car weighs 8 tons, it's definitely not the platform to get in the 9s with only 700whp. rolf:
