Replaced worn brake wear sensors but still getting Service Brakes Visit Workshop Mes
Old Jan 9, 2012 | 11:58 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Can this code be cleared by disconnecting the battery or does it need to be cleared by a code reader or the dealer? I typically replace my pads before the sensor wears down, but wore them down more this time. Thanks in advance!
Old Jan 10, 2012 | 12:07 AM
GT-ER's Avatar
2005 E55 AMG
You have to scan the vehicle with star diagnosis. It could be something else. That same message in my car was due to a faulty brake pressure reservoir.
Old Jan 10, 2012 | 12:22 AM
bbearden's Avatar
Thanks, I agree that I need to get it scanned to check if its an SBC issue or brake switch, but if it were only the sensors setting off the light, wouldn't the light reset once I put in new sensors alonmg with my brakes?
Old Jan 10, 2012 | 12:33 AM
GT-ER's Avatar
2005 E55 AMG
The break wear message is different, it actually says "brake wear" or something like that. It's not the same message as the one you are getting.
Old Jan 10, 2012 | 01:03 AM
bbearden's Avatar
Thanks, I was not aware the message was different. Looks like I'll be paying the stealership a visit.
Old Jan 10, 2012 | 07:14 AM
grantwoodtx's Avatar
GLE 63S
Scan it with Star first to get the correct diagnosis. I had a similar issue and it was a faulty brake light stop switch. That's a 10 min $10 fix.
Old Jan 10, 2012 | 02:05 PM
bbearden's Avatar
I bought the brake stop lamp switch and swapped it out but the issue didn't go away. Waiting for the dealer to get back to me and find out if either the acumulator/pressure reservoir or the SBC pump was the culprit. Hoping for the latter given the warranty.
Old Jan 10, 2012 | 04:15 PM
GLE 63S
Originally Posted by bbearden
I bought the brake stop lamp switch and swapped it out but the issue didn't go away. Waiting for the dealer to get back to me and find out if either the acumulator/pressure reservoir or the SBC pump was the culprit. Hoping for the latter given the warranty. Penske throws a huge markup on their parts so I know the reservoir fix won't be cheap.
Yeah I had the dealer change out the accumulator last year and initially they wanted $700 for the part and eventually comp'd the part and labor for that. They replaced both fuel pump and filter assembly at the same time so I bet they just slipped it in under that.
Old Jan 10, 2012 | 04:21 PM
bbearden's Avatar
I wish they'd do the same for me! Got a call from the SA and found out it was the accumulator. Sets me back roughly $900. Funny enough they mentioned that they had a code for the stop lamp switch as well which I replaced this morning. It probably hadn't been cleared out yet in the ECU.
Old Nov 6, 2012 | 10:53 PM
GT-ER's Avatar
2005 E55 AMG
The part can be had for $400ish and the install literally takes like 20 minutes tops. I did mine and it was ridiculously easy.
Old Nov 7, 2012 | 02:29 AM
ahmad0658's Avatar
Brabus K8 E55 05
Would you please share with us the part number, I have the same issue too.
Old Nov 7, 2012 | 06:39 AM
GT-ER's Avatar
2005 E55 AMG
Don't have access to epc right now but you can look at yours and read it. It's the bulb shaped objects attached to your SBC.
Old Nov 7, 2012 | 08:36 AM
Manuyc's Avatar
19 f-150 limited (w/raptor engine) 06 e55,81SC Targa,08 CLK63 BLK,91 E34 M5
It's your brake light switch right under the steering wheel behind the brake pedal. It's ten dollars at the dealer
