I/C Pump Johnson CM 90
Old Feb 23, 2012 | 08:35 AM
munich55's Avatar
E55 AMG W210 - sold, E55 AMG W211 - sold, CLS 500 C219 - sold, E63S AMG W212 - sold, C63S AMG A205
I can't find an reducer or something like that for the pump.
In need one in 1 1/2'' to 3/4''.
Can somebody help me???
Old Feb 23, 2012 | 02:24 PM
munich55's Avatar
A friend made some for me
Old Mar 27, 2012 | 08:23 AM
munich55's Avatar
I already installed it.
Damn this pump is really loud.
What should be done next?
Splitting the i/c circuit or should i wait for installing an bigger Heatexchanger?
Old Mar 27, 2012 | 08:32 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Split it ... not sure these bigger h/e help that much over OEM esp if u have a rear tank. So would rather add a rear tank before I changed the front h/e.
Old Mar 27, 2012 | 10:32 AM
munich55's Avatar
Hmmm okay.
My Problem is, i can't find an 3/4'' to 3/4'' connector as an 3/4'' to 5/8'' reducer here in Germany :-(
Is there somewhere an adress where i can get them???
Old Mar 27, 2012 | 09:32 PM
dtohio's Avatar
05,cl65;33ford3wc.
Hi, don't know what you have on your pump, but Jegs and many others have a good selection of AN fittings.
Old Mar 28, 2012 | 05:13 AM
  #32
munich55's Avatar
Okay i found everthing for splitting.
Next problem. The pump didn't start today.
I wired it like the factory one.
Is there maybe an bigger fuse needed?
Old Apr 19, 2012 | 02:54 AM
  #33
adamvondory's Avatar
Chrysler Crossfire SRT-6
Hi!
I'm just doing the same modification on my SRT-6 and it seems that the CM90 pump should be using 10A fuse(max output is 125W) compared to the CM30(3A fuse) which everybody else are running.
Old Apr 19, 2012 | 03:06 AM
  #34
stevebez's Avatar
Few things with this pump.
You need a relay to run it and use the stock power feed to trigger the relay. Simply tap the relay to a decent acc/power source with suffcient current (10Amp as its ~125w motor). The OEM power feed is only good for 5A I think. It wont work, and may compromise the wiring.
The other issue that I think some are missing on a pump like this is it does not flaw anything as fast as its max capacity given the channels it has to follow, but it does ensure a decent amount of pressure, ensuring there are no air pockets anywhere and also allows you to run thinner lines - convenient if anyone tried to route pipes for a rear tank.
I see you fitted a reducer to the inlet... this is not a good idea. The impeller needs to bite on a decent volume of water for it not to cavitate. I think it works ideal as a rear mount tank pump but too big for a front mount. The additional benefit is its strong enough to run as a single pump for a rear use application, and also servicable as the motor splits from the impeller housing.
YMMV
Old Apr 19, 2012 | 04:40 AM
  #35
munich55's Avatar
Thanks Steve.
I wired mine like stock and did an 10amp fuse in the trunk (GND) and an extra wire for + with an 10amp fuse.
What i realized. The frist days after i installed it, it was really loud.
I heard it clearly inside the car. Now it's much more quiet so i'm sometimes not sure if it really works.
Old Mar 5, 2015 | 10:14 PM
  #36
CerBErusM113's Avatar
2015 CLS63 S AMG
Hey guys,
Been reading all the I/C pump threads I can find and am in no way knowledgable on this but have picked up quite a lot of good information from you all.
I just got a CL55 which I know is slightly different from the E/CLS systems by adding a H/E vs replacing it.
In your opinions is the Meziere too powerful a pump even with a large additional H/E?
Thinking of the ZZperformance or one from frozen boost.
Old Mar 6, 2015 | 08:05 PM
  #37
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Originally Posted by CerBErusM113
Hey guys,
I have the mighty CWA-100 pump in my CL. However i could not spot any huge difference last summer compared to an "older" Bosch 010 pump. It recovers a tiny bit quicker maybe... Maybe... It runs only on 5.5-6A which i strange, since it should consume 10A according to the data sheet.
Yes i also search for a cheap HE for my CL. We already have that huge front HE and i found the -10C fan mod to be veeery good in support to reducing IATs during hot summer days.
Although i made an "-8C" mod out of it... -10 means fan running all the time in summer once warmed up which is a bit annoying IMHO.
Old Mar 6, 2015 | 08:51 PM
  #38
2015 CLS63 S AMG
Thanks for the quick reply and yes I've looked at the -10C mod, and will be doing that once I get it hooked up to an SDS (know some folks with one) and the fan mod will just remind me of my C55 with broken fan module that ran 24/7.
Also is the CWA-100 plug n play or do I have to wire it into the previous pump's harness?
Old Mar 7, 2015 | 09:41 AM
  #39
dtohio's Avatar
05,cl65;33ford3wc.
amp draw.
I think your low amp draw is likely due to the systems flow impedance not enough to work the pump to its max. The 10 amps is a max effort number. Your 5a is a good thing.
