- Mercedes-Benz E-Class: VIN Decoder
Important information to help you understand your Mercedes-Benz
Build Sheet from VIN??
Mostly asking because I assumed I do not have P030 but based on the drifting performance so far, I really don't know if it is electronically brake-biasing the power between wheels or if I lucked out.
This one shows no performance package: https://www.vindecoderz.com/EN/check...UF76J23A380836
WDDHF7GB2EA843108
Thank you,
Albert
WDDEJ7HB4AA024918
WDDHF7GB2EA843108
Thank you,
Albert
WDDEJ7HB4AA024918
Just to be constructive.....I would like to add that I found this site not mentioned on this thread.
https://www.datamb.com/
https://itunes.apple.com/ca/app/vin-...109910464?mt=8
Thank you!
WDBSK71F97F128175
wrong forum section but I can semi answer. We have a GL550 with Active Curve which and basically the prev gen version. The new GLS version uses elec controls vs hydraulic. There is a huge diff between one with and without. Even selecting comfort I can tell. Using Sport setting this big SUV feels like a steady sedan in corners.
Our Rover LR3 taking one turn on interstate has to go 60ish while the GL is steady at 75.
Also crazy on some crazy nearly circular on ramps you can basically feel the car pushing you/SUV the other direction to stay flat in the turn. It’s really cool and odd.
if you are leasing get it if you are buying and keeping long term get it. If buying and the swapping in a few years maybe pass. It took us nearly 4mths to find a GL550 with it in the right color combo. Hell even on the ones we didn’t want they didn’t have it. Best guess is bc it was expensive and dealers didn’t keep one to test on the lot many just skipped it thinking it didn’t make enough diff. The AMGs had it standard which is what we tested it in.
