POST DYNO THOUGHTS
Old Feb 6, 2012 | 06:22 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Originally Posted by emoving
Cant really compare long tubes to shorties that also retain the CATs can you?
Correct.. Exactly why he may have put down more rwhp than you (even given same weather conditions, dyno etc)
Old Feb 6, 2012 | 06:25 PM
skratch77's Avatar
2005 E55
komp post up your dyno when you get a chance.
Old Feb 6, 2012 | 06:35 PM
Benz-O-Rama's Avatar
Originally Posted by komp55
Really? Then why is everyone saying "they're great numbers", they're in line with where they should be", etc.? Those sound like comparisons, too.
I get what you're saying, and agree for the most part, but since we're all comparing, I'm simply providing another data point from a Dynojet and suggesting that I would have expected higher numbers given the pulley on the car. Is there a problem with making such an observation? I'm happy for his results, but thought given the mods he's done, he should have ended up with a bit more. I believe others have.
Correct, you can't just see a post mod dyno number and say "great number". The actual number is pointless. What should be said is "nice gain".
I'm not telling you anything you don't already know.
Old Feb 6, 2012 | 07:22 PM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Ok, it gained more than 10hp. So can I have my wheels
Old Feb 6, 2012 | 07:25 PM
novae500's Avatar
W211
Originally Posted by AKnight55
The MBH headers guarantee like 30 rwhp.. I dont think the Kleemans make that much power, that might be why you would expect higher
I too would have expected more power though. Kleemann tune is also on the conservative side I believe
Mbh headers guarantee 40-45whp gains. Good gains from pre / post mods gains
Old Feb 6, 2012 | 07:30 PM
jmb614's Avatar
E55 AMG
Nice gains over an already stout stock setup. Grats, Marcus!
Old Feb 6, 2012 | 07:41 PM
  #32
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Thanks! IPS Motorsports was excellent to deal with! FYI
Old Feb 6, 2012 | 07:44 PM
  #33
Evolved8's Avatar
AMG Fam
You have to compare them to the first run which was pre install, on the same dyno in the same climate. Thats all. I am sure there is a dyno I could find that would show 550hp and I could also put it on a Mustang and probally show 350HP LOL.
My E saw those rollers
Old Feb 6, 2012 | 07:45 PM
  #34
emoving's Avatar
Post your dyno, I thought they said they ran yours on the Mustang.
Old Feb 6, 2012 | 08:06 PM
  #35
lowprofile's Avatar
E55
Everything looks on point, including producing higher #'s in 4th.
Old Feb 6, 2012 | 08:14 PM
  #36
emoving's Avatar
Now hearing from you gives me comfort. They want to port my blower but not sure if it is worth it.
Old Feb 6, 2012 | 08:15 PM
  #37
emoving's Avatar
There yours buddy.
Old Feb 6, 2012 | 08:17 PM
  #38
E55Bullet's Avatar
Throw this up in a new thread and see what people have to say. Like I said earlier I think people have done it, just no proven results... As far as I know
Old Feb 6, 2012 | 08:49 PM
  #39
BlackTTC6's Avatar
2006 E55 Amg
This dyno was done today after the Kleemann headers, tune and pulley was installed. Thoughts? 1st pull was pre install. 2nd was post install 4th gear and third was post 3rd gear. Notice the torque drop in third compared to 4th.
http://www.youtube.com/watch?v=4Z7N2TPsErA
http://www.youtube.com/watch?v=_BtBJ0XcU4o
Whats up with the top end of the graph? Blower just not big enough to push big numbers?
Old Feb 6, 2012 | 10:18 PM
  #40
chawkins2001's Avatar
2006 E55 AMG
My evaluation is as follows:
The mod gain is very stout, making those numbers with that amount of bolt ons is impressive.
In true kleeman fashion the tune is super safe in the upper rpm range, pig rich actually. It looks like it dips into the deep 10's which is misleading because the only reason it does that is due to the long 4th gear pull. That generates alot of heat and the ecu did its job by dumping alot of fuel trying to cool things down.
My car did the exact samething on a 4th gear pull. I guarentee the 3rd gear pull a|f ratios were leaner and in the 11's due to less heat soak from the pull.
What is so impressive with kleeman tunes is how they hold the power up top. Between 5-6k rpms, the power does not drop off at all, which is characteristic of alot of other tuners.
I would be smitten if that was my investment homey.
Old Feb 6, 2012 | 10:23 PM
  #41
2006 E55 AMG
Oh, do NOT port a twin screw. You will ruine the blower and not gain anything.
Twin screws are not like eaton or roots blowers that can benefit from a port.
Old Feb 6, 2012 | 10:26 PM
  #42
skratch77's Avatar
2005 E55
let me know when 480whp feels slow and I will trade u my oem 178 for your 168.
My 178 is exactly made like a kleemann/renntech/brabus pulley and uses a stock oem pulley with a bigger outer ring placed on it and not welded.
Old Feb 6, 2012 | 10:31 PM
  #43
emoving's Avatar
Exactly what they said at the shop today.
Old Feb 7, 2012 | 09:05 AM
  #44
2006 E55 AMG
Woah, I am not as dumb as I thought, someone else thinks like me too
Old Feb 7, 2012 | 10:12 AM
  #45
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
+55!!!!
Huge gains Marcus
Old Feb 7, 2012 | 02:04 PM
  #46
Evolved8's Avatar
AMG Fam
Yes that's what I meant, It saw the mustang dyno and made 507rwhp and 57x rwtq. Ill post it up If i can find it!!
Old Feb 7, 2012 | 08:09 PM
  #47
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Damn, I want some Floored Fab LTs!
Old Feb 7, 2012 | 08:21 PM
  #48
AKnight55's Avatar
They had a group buy before your existence here
Old Feb 7, 2012 | 08:30 PM
  #49
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Thanks bro, I existed here too late
