PORTED FACTORY BLOWER
Old Feb 6, 2012 | 08:20 PM
emoving's Avatar
3-five-five/ TUNDRA/ 07 997 cab
Is it worth is and what would be aprox gains? My shop mentioned it today but I was unsure as what the results would be. It seems people have done it but combined with TBs and other stuff so no real numbers.
Old Feb 6, 2012 | 08:23 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Mine as well do TB first
Old Feb 6, 2012 | 08:37 PM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
I've been wondering about this is well. Seemed to be somewhat popular on the blowers on the Ford Lightning maybe chawkins will pop in and shed more light on this as he had a lightning I believe. I'm not even sure what exactly get's ported on a blower like this to be honest.
A throttle body port can be done by most anyone with a dremel and some common sense, patience, and a somewhat steady hand.
Old Feb 6, 2012 | 08:40 PM
lowprofile's Avatar
E55
IMO, you could definitely spend your $$$ in better areas. As mentioned, the throttle body is one of them.
Old Feb 6, 2012 | 08:43 PM
emoving's Avatar
They wanted around $800.
Old Feb 6, 2012 | 08:55 PM
e55amgrocket's Avatar
Dirt Scooters
I wasted my $$ sending mine to stiegemier in Dec 2010 for them to do some "clean up/opening up" and was then told that our blowers don't really offer much room for improvement like the eaton blowers do.
BBBSS's Avatar
$800 For a new throttle body, or to port one? Who does porting on the throttle bodies?
Old Feb 6, 2012 | 09:03 PM
emoving's Avatar
This is what I kinda thought I had heard before.
No, that was for the SC port.
Old Feb 6, 2012 | 09:11 PM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
slowly. . .step away from your "misc account" credit card, bank card, checks and any other form of payment you use for your toys. The first step to beating addiction is to acknowledge your addiction. I officially volunteer to be your "sponsor". . .now go make amends with your wife.
Old Feb 6, 2012 | 09:13 PM
emoving's Avatar
Haaaaaa, you know me bro! She thinks it went in for a new SC belt!
Old Feb 6, 2012 | 09:35 PM
emoving's Avatar
Chad, phone went dead, cant text for a minute.
Old Feb 6, 2012 | 10:01 PM
chawkins2001's Avatar
2006 E55 AMG
You cannot port the Lysolm twin screw, it is not beneficial at all. Twin screws are not like roots or eaton blowers that benefit fron port jobs.
Old Feb 7, 2012 | 11:24 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
+1 with above. Just try to open that TB up as much as possible. Our cars are STARVING for air. When we were dyno tuning my car, new airbox (vrp) and part that connects the blower to the TB (forgot the name) gained me 20-30wheel hp over stock. Again it was on a highly modified car that was starving for air.
Old Feb 7, 2012 | 01:59 PM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
not only opening TB also try to open up the other side after S/C beneath when you flip S/C, DTM S/C and SLR has a bigger out way after S/C.
Old Feb 7, 2012 | 02:28 PM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
Start with grinding your TB... took me a few hours but its easy.
http://www.youtube.com/watch?v=4O61f...dknsf8j9UtdmwK
Old Feb 7, 2012 | 02:36 PM
AKnight55's Avatar
Ill even sell you a ground down TB that Pearlpower had professionally done..
$150 plus shipping
Old Feb 7, 2012 | 03:42 PM
Bramage's Avatar
F-250
maxbore does awesome work. You will see 2 MB TB's ported on thier web site. I know one of those guys....
They will grind shaft too, but you need to make sure to TELL the guy in advance
Old Feb 7, 2012 | 07:41 PM
Toadster's Avatar
2005 E55 AMG
port matching has always been worthwhile - I don't see why it wouldn't benefit the blower
the guy in this thread gained 28hp/28tq - different vehicle, but it's proving what you'd want to do... it's just optimizing airflow
http://www.modularfords.com/f73/port...nifold-159331/
Old Feb 8, 2012 | 05:01 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I found with ported heads, it does help to open the intake inlets up on the blower ports that bolt to intake ports. Did not mess with the air inlet into the rotors but did clean up the blower TB inlet some. If all that make sense.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
