lugbolt question science guys opinions please
can anyone confirm this? wouldnt it cause a wobble?
That sounds crazy!
any sound advice would be appreciated
they go on to say most wheel companies drill the wheels for 14mm even though they are sold to folks with 12mm lugbolts
AMG uses a 14 x 1.5mm thread pitch with a ball seat. I would offer that if either the ball seat or cone fit the wheel correctly (i.e., sit correctly in the mounting bolt hole on the wheel, that's what applies the clamping force against the hub face when torqued to the correct specification. Assuming the center hole of the rim is hubcentric, then it would be okay to use a 12mm thread pitch under these circumstances. Lateral forces on the rim are secured primarily by the wheel bolts (which fit the wheel type correctly - cone or ball), and radial forces are controlled by the hubcentric fit of the rim (primarily), with a little additional help from the wheel bolts holding the rim in location on the hub. I would advise against using 12 bolts on a 14mm bolt hole wheel if you're also using an aftermarket hubcentric centering adapter. Those types of inserts, especially if made of hard plastic or aluminum tend fail over time creating vibration issues since the wheel is no longer centered correctly. The only really excellent hubcentric adapter system that I have confidence in is the BBS PFS system, which uses hardened metal center bore rings of precise fitment (which unfortunately can only be used on BBS rims).
AMG uses a 14 x 1.5mm thread pitch with a ball seat. I would offer that if either the ball seat or cone fit the wheel correctly (i.e., sit correctly in the mounting bolt hole on the wheel, that's what applies the clamping force against the hub face when torqued to the correct specification. Assuming the center hole of the rim is hubcentric, then it would be okay to use a 12mm thread pitch under these circumstances. Lateral forces on the rim are secured primarily by the wheel bolts (which fit the wheel type correctly - cone or ball), and lateral forces are controlled by the hubcentric fit of the rim (primarily), with a little additional help from the wheel bolts holding the rim in location on the hub. I would advise against using 12 bolts on a 14mm bolt hole wheel if you're also using an aftermarket hubcentric centering adapter. Those types of inserts, especially if made of hard plastic or aluminum tend fail over time creating vibration issues since the wheel is no longer centered correctly. The only really excellent hubcentric adapter system that I have confidence in is the BBS PFS system, which uses hardened metal center bore rings of precise fitment (which unfortunately can only be used on BBS rims).-Craig
