I want advice
E55 AMG 2004
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
I have E55 AMG W211 2004
I want to canceled one or both What do you advise the number 1 or number 2
Look at the illustration below
http://imageshack.us/photo/my-images/832/amg444.png/
E55 AMG 2004
E55 AMG 2004
Do you have emissions testing where you live? If not, then do away with both and do mid pipe/x pipe, straight pipe to the muffler. If too loud, then keep the resonator
2010 E350, 2011 ML350, 2003 996TT
That makes NO sense. The piping is already 'empty'. Are you talking about punching through the cats? That's really pointless since you will need to cut them off to do that anyways and if you're going through the trouble, you may as well just weld in an x-pipe.
If you really knew about this car, removing the resonator makes 0 difference to power and the sound change is almost imperceptible.
Please refrain from you senseless contributions until you have some experience with the car.
E55 AMG 2004
I'm afraid if I cut Mufflers and put in place of x-pipe welds to disintegrate after a period of time ... But the question is .. Is it true that the Mufflers empty?
If you were speaking from experience or from the knowledge gained via extensive searches you've conducted I'd be inclined to listen to you. BUT I don't think I've ever heard the suggestion of trying different resonators mentioned ever!
and if you say
Actually i DO have experience here, in one of my past vehicles it was common to replace the resonator with a different piece which wouldn't do anything but keep the drone at bay, but also give it a different tone for the exhaust - and it worked well...
and if you say then why does everyone recommend doing it in the first place?![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Removing the resonator just makes it cleaner and saves weight... see you just proved your inexperience with these cars!
2004 W211 E55K, GL550
IMO i would do both as said above x pipe and straight pipe.
