Car nosedives on 2-3 shift
Old Feb 20, 2012 | 08:24 PM
Sir-Boost-a-Lot's Avatar
1967 Pro Touring turbo LSX Camaro
I saw a few people bring this up in e55amgrocket's "10sec" thread and didn't see the need for further hijacking so heres it's own thread.
Ive had this car two weeks and floored it from a stop for the first time today racing a 350z out of a toll booth. I instantly pulled a few car lengths on him but on the 2-3 shift felt like the car slammed into the rev limiter. It completely fell on it's face for about a half a second then came back alive and commenced the asskicking once again.
I have no way of data logging this car to see requested shift points vs rpm, and actual rpm observed vs. indicated and so on..
Is this a tuning issue? Trans hard parts issue? Both mabye as in the TCM not adjusting line pressure to compensate for worn friction material?
Old Feb 20, 2012 | 08:27 PM
Shifter's Avatar
E55, SL63, ML550
What drive mode were you in? Manually shifting?
Denroll's Avatar
'06 E55
We need to get to the bottom of this. Next time I go to the track, I'm going to try shifting in M mode with the foot planted to the floor.
Old Feb 20, 2012 | 08:32 PM
Just plain old "D". Does the manual mode even do anything? In my 335 it was aways a tenth or two quicker if you left it the **** alone.
Old Feb 20, 2012 | 09:04 PM
RedBullJnky's Avatar
you to Hate
I agree. . My car does this also, but only at WOT.
I've ran at the track in S and M. And M mode works best for me, as I have heat issues. And I shift at a certain rpm so that the car stays in peak tq. But my car is at the shop now being worked on and then all my cooling mods will be installed. Hopefully this will solve the heat issue, but we still have to fix the shifting problem. I'm getting a TCU tune and a retune from Jerry so maybe he can fix it.
Old Feb 20, 2012 | 11:29 PM
GT-ER's Avatar
2005 E55 AMG
This is "normal" for the E55. Seems to be the engine pulling timing to allow for a softer shift. Jerry retuned my car today to see if he could eliminate the issue with no luck, my car still does it. Let's see what comes out of this.
Old Feb 21, 2012 | 12:12 AM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
On mine the logs show that it isn't pulling timing but closing the TB. I'll send Jerry some of my logs.
Old Feb 21, 2012 | 12:14 AM
GT-ER's Avatar
2005 E55 AMG
That could be it as well.
Old Feb 21, 2012 | 12:58 AM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
That's what it feels like to me as well, as if the ECU was pulling timing on the 2-3 shift but it never did this before the ECU and TCU tune. I'm in S mode with the shifter in D (no manual shifting) and it does this at WOT near redline. Very annoying, we need to get to the bottom of it.
Old Feb 21, 2012 | 05:53 AM
Roverron's Avatar
ML63
Mine never did this before the TCU tune.
I thought my car was hitting the rev limiter and that's what I was describing to the guys at E.C. but I see now that it is something different.
I didn't notice it at first because I rarely go full throttle. <---- I know those words bring back bad memories. LOL..
Old Feb 21, 2012 | 07:16 AM
audibiturbo's Avatar
W219 CLS55AMG
Same issue for my cls55, car makes 510whp, with camshaft.
really wanna fix.
Old Feb 21, 2012 | 10:07 AM
adianaty's Avatar
Same here. Never had a problem until TCU tune was installed.
Old Feb 21, 2012 | 10:11 AM
Evolved8's Avatar
AMG Fam
Same issue here mods as followed in my sig. Track use at WOT does it every time
Old Feb 21, 2012 | 10:13 AM
xtyper's Avatar
2013 E63 AMG
I had this same issue at the drag strip this past weekend and posted a similar thread on the c63 forum.
https://mbworld.org/forums/c63-amg-w...rag-strip.html
Old Feb 21, 2012 | 10:29 AM
W219 CLS55AMG
In my case it happened 3-4 and 4-5 shift feel like TB closed
Old Feb 21, 2012 | 10:47 AM
KLR CLS's Avatar
CLS63 PP
Happens for me too...Jerry will fix it..I am sure.
Old Feb 21, 2012 | 10:56 AM
skratch77's Avatar
2005 E55
Try turning off traction control and see if it does it.
Old Feb 21, 2012 | 11:05 AM
GT-ER's Avatar
2005 E55 AMG
I tried with both way and it does it the same. In C is does it way worse than in S but it does it.
Old Feb 21, 2012 | 11:07 AM
jmb614's Avatar
E55 AMG
https://mbworld.org/forums/5065021-post62.html
Old Feb 21, 2012 | 11:13 AM
BlkE55K's Avatar
2010 E350, 2011 ML350, 2003 996TT
Yep...me too. I thought my shift point was just higher than the engine redline, but it appears it's something else. Hopefully Jerry will have this all figured out soon so I can get it fixed while he does my retune to scale my injectors.
Old Feb 21, 2012 | 11:15 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
mine does this too and i only have headers and EC tune... the first time it happened i thought i blew the tranny lol but then it found the next gear and i changed my underwear
Old Feb 21, 2012 | 11:20 AM
skratch77's Avatar
2005 E55
Its to cold out for me to even go 40% throttle in secind gear ti even try to replicate it but i have felt this before and it did it right after i did the sneaky reset at the track.but back then i was on a different tune and i cant remember if its done it at all lately.
Ill let u know as soon as it gets warm out but from memory running my times the car shifted smooth going into 3rd at wot.
The only problem i get with my car is the tc is very sensetive to tire sizes.like when i ran a little taller tire out back the light would blink even if i had full traction
Old Feb 21, 2012 | 11:21 AM
cij911's Avatar
one car at a time
Big bummer as I just bought the ECU and TCU tune....The TCU tune has been out for a long time, so why is this just being reported now ?
Old Feb 21, 2012 | 11:45 AM
gaspam's Avatar
it is not from the TCU tune- it happens on all e55s... mine does it and i have no TCU tune as well as other members without TCU tunes reporting the same thing
Old Feb 21, 2012 | 11:51 AM
adianaty's Avatar
Just to be clear with my experience, I never had a problem prior to the TCU tune so I'm not sure we can rule it out. It is likely that the ECU is taking control of it but prior to the TCU tune I had no issues and it is not happening in all E55's either since there are 2 other cars local to me with similar mods that do not do it.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
