Car jerks in the morning when I put it in reverse
Old Mar 6, 2012 | 11:53 AM
FromM3toE55's Avatar
2003 E55 AMG
Question Car jerks in the morning when I put it in reverse
When I start my car in the morning and put in reverse it seems like it takes a second or 2 for gear to enage and I get a slight jerk. It only jerks from park to reverse or from reverse to park. Once fully warmed up it doesnt jerk when you put it in reverse.
Any help would be greatly appreciated
Old Mar 6, 2012 | 12:03 PM
Toadster's Avatar
2005 E55 AMG
IMHO lower fluid levels impact the cold movement, do you have any seeping or leakage?
Old Mar 6, 2012 | 12:06 PM
amg guy's Avatar
2024 GLE 63 S Coupe 2020 E 63 S
Mine does it too, it's noticeable. not bad, sometimes I let it warm up for 30 seconds in neutral before shifting into reverse then it doesn't do it. Mine has done it since I bought the car. I now have 65k on it and it is still the same. I always let the engine settle down to normal idle speed before shifting out of park about 15-30 seconds.
Old Mar 6, 2012 | 12:41 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Search will review responses. Bottom line, it is NOT normal. Do not let anyone tell your otherwise. Cold or Hot, should not be a jerk. Mine is buttery smooth, but I also recently rebuilt it. Mounts, engine RPM, fluids, solenoid(s), valve body, trans, etc are all culprits.
Old Mar 6, 2012 | 01:27 PM
desired_speeds's Avatar
2007 SL55 AMG
I guess you can start cheap, check trans fluid level and condition.
Old Mar 6, 2012 | 01:47 PM
2003 E55 AMG
thanks for the response guys! I just got back from the dealer and they had to add half a quart of tranny fluid and now it shifts smoother than before
none at all
