Dry Ice & Ice Experiment
I put in 4oz of dry ice and after 10min the went down 10degrees.
I then put in 44oz of ice from the fridge in the pot and after 10min the temp went down 20 degrees.
I then put in 8oz of dry ice & another 44oz of ice and after 15min the temp went down another 30 degrees.
So in 35min the temp went down 60 degrees.
So im thinking while you are icing down the SC you can drop your tank temp quite a bit between runs. If you keep at you can probably get it down do 40 degrees in 45min.
Can you cycle water through the system between rounds? If you can I'd use dry ice and a lot of it.
