Any write-ups for cam install
Old Mar 12, 2012 | 01:18 PM
cfi_luz's Avatar
2006 SL55
I've tried to search but I can't find much. Anyone have a basic how-to or tips for installing cams in this car?
Old Mar 12, 2012 | 01:43 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
remove valve cover,
remove alternator,
loosen cam chain tensioner bolt,
zip tie the cam sprokets to the cam chain so timing is not messed up,
undo bolts on the valve train in a star pattern and remove valve train
undo bolt on cam sproket and cam will come off
Old Mar 12, 2012 | 01:57 PM
e55amgrocket's Avatar
Dirt Scooters
Cam's are pretty easy honestly. When you have Blackbenzz helping they are twice as easy lol
Old Mar 12, 2012 | 02:05 PM
cfi_luz's Avatar
2006 SL55
Thanks for the responses guys. I've done many cam installs in other cars so I can turn a wrench, but it helps to outline the process before getting started. Are any special MB tools required such as the cam sprocket holding things,etc?
Old Mar 12, 2012 | 02:09 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Yes, real easy job, like Shardul said. Let me add that before you start,to put the flywheel on the 40 eg mark or top dead center. Dont have to do this but it does give a reference, in case you ran into a chain issue.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Mar 12, 2012 | 03:21 PM
blackbenzz's Avatar
haters crazy
Haha. I think I can do heads/cams blindfolded now
Mb dies special tools that come in handy. One is for cam gear bolts and the other two are cam locking tools. Give me your email, I have a great pdf to walk you through stretto by step. For an na car but same thing basically
You can set it using the cam locking tools too
Old Mar 12, 2012 | 03:51 PM
cfi_luz's Avatar
2006 SL55
PM sent, thank you!!
Old Mar 12, 2012 | 04:02 PM
blackbenzz's Avatar
haters crazy
You have mail. Your welcome. The pdf has torque specs, step by step instructions with pictures, Mb tool part numbers, etc etc. its very useful
Old Mar 12, 2012 | 05:13 PM
cfi_luz's Avatar
2006 SL55
You're the man!
Old Mar 12, 2012 | 05:27 PM
Evolved8's Avatar
AMG Fam
There is a write up floating around on here for kleeman cams.
Old Mar 12, 2012 | 05:47 PM
jcjmw's Avatar
2005 E55 Wagon
Can you also pm me....please?
Old Mar 12, 2012 | 05:57 PM
jcjmw's Avatar
2005 E55 Wagon
Old Mar 12, 2012 | 06:33 PM
blackbenzz's Avatar
haters crazy
You're the man!
Haha thanks. Let me know if you have any questions
Sure just pm me your email and I will send it
Old Mar 12, 2012 | 10:31 PM
jcjmw's Avatar
2005 E55 Wagon
Thank You!!!
Old Mar 12, 2012 | 10:40 PM
blackbenzz's Avatar
haters crazy
Thank You!!!
Your welcome
Old Apr 21, 2025 | 05:03 PM
LowKE55's Avatar
Is this write up for the M113K? I'd be interested too- i can't seem to PM you though.
