773hp & 925tq MHP E63 Tune Results
Old Apr 3, 2012 | 12:19 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Just no denying it anymore. The Supercharged 5.5 just doesn't even come close to the mighty twin turb'd 5.5
Soon as Benz depreciation does it's job, I am ditching asap for Turby Town.
Old Apr 3, 2012 | 12:27 PM
Vic55's Avatar
Administrator
Great and that means the little kids will have theirs in about 7 years...
Old Apr 3, 2012 | 01:27 PM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by bghark
Maybe I am just an old man but I can't see how you could get performance jumps like that on a tune? I just can't see how you would get enough fuel. Stock injectors and stock heads, stock cams? You have to get the mix into the cylinder first. I have a lot of experience with blowers but alas, I need to study up more on turbo charging. I very well could be wrong but I would like something concrete. I am sure it is around the corner. If it is true, and you can get that car to hook up at the track, it would be nuts!
You have to remember that, unlike a supercharged engine, a modern turbo engine has it's boost controlled by the ECU. When you flash the ECU you can raise the boost pressure electronically. That's where the big power comes from.
From the looks of that graph, that engine is choked big time after 5Krpm...it would be interesting to see what the next weakest link would be. Exhaust? Intake? Turbos?
Old Apr 3, 2012 | 01:32 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
That's why i am not modding my E55 anymore. Keep it as it for the next 2 years and will pick up a 63TT. So basically this new V8 63TT perform better than 65 V12TT ???
Old Apr 3, 2012 | 01:41 PM
e500slr's Avatar
2011 E63, 2013 CLS63
It's lighter and it's more advanced so yes I would say it has a huge advantage over the V12s. It's better for handling, braking, weight plus being a TT it's not like the V12s are gonna have an advantage over it even by size and cylinders. The new engine is a beast, I agree with you on keeping an E55 stock and then getting the 5.5TTs when they become a little cheaper. I mean tune only and these results...JESUS
Old Apr 3, 2012 | 02:32 PM
CharlyE500's Avatar
+1 imagine tune + Header ! it should run low 10's ! Plus, 7speed and better handling. I love my E55K but just don't see any reason to dump more money on it if picking up 63TT in 2 years. Hopefully this 63TT is as reliable as our 55K....... we will see.
Old Apr 3, 2012 | 02:49 PM
  #32
bghark's Avatar
2006 E55 AMG
Originally Posted by e55amgrocket
I think it's very possible. These engines have direct injection and not typical fuel injectors. The fuel is sprayed right on top of the piston and at very high pressure (over 1,000 psi) and is much more efficient than normal fuel injectors. The injection pumps are also capable of delivering a lot more fuel stock too. I think this is just a look into the future of where things are going.
You have to love a bright and insightful anwser. Thanks so much. Always nice to learn new things, especialy from a proven expert.
Old Apr 3, 2012 | 03:43 PM
  #33
Thericker's Avatar
V12-Biturbo
Jeez you guys sure do FORGET MHP fast... Don't you guys remember his claims of 1000 hp 1200+ tq on the 65 V12tt & what'd he end up really making in the real world? Couldn't even run a high 10... If memory serves it was 11.07 @ 128-129 mph..
You guys think RENNtech left that much rwhp rwtq on the table in their CLS63 tunes? High 570's & low to mid 620-640 rwtq the NEW trans isn't the reason either, MHP is Modern Horse-s!hit Period... The ONLY success he had was marginal ie Tune vs Tune ONLY on C63 platform that is severly neutered from factory so take this Graph & lame dyno run w/grain of salt MHP's rep here speaks volumes to the level headed here
The new V8TT is near max Boost w/PP option, the tunes just change the boost character & hold it longer in each gear vs stock, their isn't another 10+ psi left on the table to capture these claims..W/out bigger IC's/Turbo's look @ the CLStt w/aftermarket larger Turbs he's pushing these type of #'s Not happening w/ECU only
Here's the quote from Dubai cls63 w/custom larger Turbo build made 641 rwhp POST turbo upgrades..
Originally Posted by dbasons55
Just a small history on my car and the dyno runs, my car is a CLS63 with PP, my first dyno was 529whp on the dynojet, after i installed the Brabus piggy back i dynoed at 579.5whp ONCE only the piggy back was not good where i had different readings from 540-579, they then installed another one after fixing it, my car read 550-554 constent. All on the same Dynojet, this is my results with the new upgrade, bare in mind this is the first base tune my car is getting another tune as i am typing this and will get more once my custom exhaust is ready in two weeks, and someother goodies.
The POST Turbo upgrade TQ graph read 683 rwtq please explain how MHP can get 23 LESS rwhp & 57 MORE rwtq from ECU Tune only sheesh gullible is a word that comes to mind here.. MHP ECU only 618 rwhp 740 rwtq
Here's dbasons55 POST Turbo upgrade DynoJet graph.. Note RWTQ is in Newton Meters converts to 683 not 900..
Old Apr 3, 2012 | 05:24 PM
  #34
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i would think downpipes would be the first next easy HP pickup on a TT.. downpipes yield pretty significant gains on the cheap with TT'd cars.
i said TT
Old Apr 3, 2012 | 05:50 PM
  #35
BenzoBoi's Avatar
Super Moderator
W221
BUT...
Will stay tuned for more info...the numbers do seem high for tune only...
Old Apr 3, 2012 | 08:33 PM
  #36
MoFetti's Avatar
W211 E63
A little high for a tune, but we shall see.
Old Apr 3, 2012 | 08:52 PM
  #37
Rock's Avatar
Administrator
Drives Slowly
I think it is only fair to let Andy chime in.......oh wait............... never mind.
Old Apr 3, 2012 | 10:30 PM
  #38
Hammer Down's Avatar
2015 E63S, 2018 E63S
Rock, how in the hell have you been? So after 3yrs how do you like the GTR?
Old Apr 3, 2012 | 10:34 PM
  #39
Vic what was that GTR site that you mentioned awhile back? I'm trying to decide on a CLK Black Series or a GTR to compliment the E55
Old Apr 3, 2012 | 11:07 PM
  #40
Forrest Gump 9's Avatar
shrimp boat
The car was dyno at the shop near by my house. I talked to the shop owner, he said the gain was real. Boost was 20 psi.
Old Apr 3, 2012 | 11:51 PM
  #41
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
I'd like to know where you even got the 9.5% from. I agree with the bold parts though.
from AMG techs when MB/AMG staff were here for F1 in Yas Marina
already discused with them the new TT engines shows higher number on dyno and they clearly stated
" what are you talking about !! we use engine dyno and therefore the engine output is in KW what we are claiming, however drivetrain loss is a lot less in these cars"
who am i to argue with them ^_^
so unless some one pulls the engine out of the car and put it on a " engine dyno " and give us a fly wheel hp, i will stick with what AMG engineers says.
Old Apr 3, 2012 | 11:57 PM
  #42
Ali_E55's Avatar
you are right, our new TT have a fuel pump under the hood that send more than 200 bar pressure to these injectors + they have new fuel retainer, etc.
Old Apr 4, 2012 | 12:29 AM
  #43
e500slr's Avatar
True but the CLS63 has already run a 10 so they've started out really great.
Old Apr 4, 2012 | 01:49 AM
  #44
Thericker's Avatar
V12-Biturbo
Yes... But that has already been discussed to death NOT W/TUNE ONLY
RENNtech added Down Pipes, Hi-Flo or NO Cats, light Skinny's up front, light 18"s or less on Drag tires RR, RENN-LSD 93 ECU + more than likely added few gallons of 100+ oct @ Race Track etc...Please stop blurting, it's so easy for you to go back & re-read that thread before stating the CLS 63 ran 10's w/ECU only sweet jeezus this place is kandy land..
If you want to compare mod for mod, Claytons SL600 runs Basement 11.02 etc repeatedly on Stock front & rear 18" wheels, Drag tires out back MODS are ONLY ECU/TCU 93 oct, if the guy thru skinny's up front guaranteed 10's ALL DAY...
Old Apr 4, 2012 | 04:19 AM
  #45
e500slr's Avatar
I didn't mean tune only I just ment the car itself did. I know it wasn't tune only.
