SC rotor bearings
Over the weekend I finally open up the spare SC that I had. And in the process I damaged one of the rotor bearing. The local bearing warehouse can't help me, and searching the forum/web didn't help neither. So hopefully the E55 expert can help me out.
BTW, how did you damage the bearing? I took one a part once but planning to take mine apart again to do some work.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Interesting observation: It required almost three times the amount of new oil than the amount drained. I know these units are sealed, but is it possible small amounts of oil are consumed over time? The old oil smelled pretty bad and the new oil (Mobil Jet) had the normal order. I have had jet turbine aircraft which use the same oil. I do not recall the used oil smelling so bad.
Do tell. I'm sure someone has an extra s/c laying around. They can pull the old bearings and send them off as a template. I think ceramic is freaking cool stuff.
