E55 will not do a burn-out.
#53
V12-Biturbo
Tire Size ComparisonSpecification Sidewall Radius Diameter Circumference Revs/Mile Difference 255/35-18 3.5in 12.5in 25.0in 78.6in 806 0.0% 265/40-18 4.2in 13.2in 26.3in 82.8in 765 5.3% Back to the CalculatorCopyright 1996-2001,*Eunos Communications LLC
#54
I had issues with the taller tires but im running stock sizes now to keep the traction system happy.
My car wont shift at all on its own in m mode,it will bounce off the rev limiter.im going to the dealer tom and telling them to flash my tcu to latest firmware.
#55
V12-Biturbo
That should sort it out, my guess is it may take couple 100 mi to adapt
If you left it as is, ECU hates dif DIA tires/wheels frnt to rr... It may adjust w/time on it's own after a load of driving w/new = sized wheels
#56
His set up was 245/40/18 and 265/40/18 so only a 2.4 % difference
#62
Just throwing an idea into the pot... but could maybe be a function of SBC stepping in sensing the front wheels aren't moving after a few seconds, then braking the rear wheels for some reason? Those that have successful burnouts longer than 2 seconds, are you staying completely still, or is it a slow roll like in the video cwmateiuc posted on pg1? Like someone said, i think there are multiple issues being discussed.
#63
I have an '03 and cannot do burnouts. Car loses traction and ESP pulls power. Even when rolling, except on hottest days, engine will pull power as ESP starts to flash. Very annoying. The strange thing is, before installing K1,car would spin tires nicely from the dig without bogging the engine. It seems like the increase in power from the K1 mod, which is up quite a bit, is causing ESP to pull power.
