A/C compressor is making a whining/groaning noise? Anyone replace it before?
Old May 24, 2012 | 10:11 AM
B Feelgood's Avatar
SL63, GTR
These threads sound like the symptoms I have
http://www.benzworld.org/forums/w210...or-pulley.html
http://www.benzworld.org/forums/w210...nder-hood.html
"i have the same problem and posted it several times. there is a whining sound that is consistent with the engine speed. the whining sounds like a power steering pump that is low on fluid. the noise is the same with the compressor engaged or not engaged. all of the values are right on through the climate system. i have removed the belt and the pulley moves freely without play."
Old Jul 11, 2012 | 08:34 AM
streetspeeder's Avatar
2006 E55 AMG
Hi,
Did this ever get resolved?
Old Jul 23, 2012 | 11:02 PM
madaniann's Avatar
E500
Having the same problem
B Feelgood did you ever find a solution to your problem? I'm have the exact same issue. I can't pinpoint the noise to any of the pulleys or the transmission pump. I did the same test with taking the belt off but the noise was still there. Any help is greatly appreciated.
Old Oct 23, 2012 | 01:18 PM
B Feelgood's Avatar
SL63, GTR
Never did find the solution for this and I drove it all summer without any problems. The air conditioning works fine and gets cold. The noise is extremely annoying however and I am looking into replacing the AC compressor "per the dealer's recommendation" since I have nothing else to go on.
Old Oct 23, 2012 | 04:38 PM
black06c230's Avatar
mgLipGD
Check partsgeek.com I got one for I think $400 - $450 shipped.
Old Oct 24, 2012 | 11:05 AM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Alldatadiy.com has symptom related information as well as testing and repair at your fingertips. Good luck with your repair.
Old Feb 1, 2015 | 05:30 PM
  #32
jrevivo's Avatar
sl55 amg
Any Update?
Just bought an 03 sl55 and have the same deal going on. Any resolution?
Jessy
Old Feb 1, 2015 | 09:39 PM
  #33
SICAMG's Avatar
2005 e55 AMG
Tell us exactly what the noise is like ...when,cold,hot,drive,reverse, shifting.
Old Feb 1, 2015 | 10:37 PM
  #34
jrevivo's Avatar
sl55 amg
Noise
Identical symptoms to the original post. Sounds like the power steering pump is blown but its constant, in every gear. It's the typical cold start whine that doesn't go away. Wondering if it had to do with the a/c compressor.
Old Feb 2, 2015 | 10:28 AM
  #35
SICAMG's Avatar
2005 e55 AMG
Mine has the engine oil pump whine when cold and dies down when it warms up. Is that what you hear/sounds like?
Old Feb 2, 2015 | 12:00 PM
  #36
jrevivo's Avatar
sl55 amg
Possibly but the sound continues. Never dies out.
Old Feb 2, 2015 | 12:40 PM
  #37
SICAMG's Avatar
2005 e55 AMG
Again an accurate diagnosis is important so you can narrow it down. Listen to eat when you drive and check again.
Old Apr 18, 2015 | 11:30 PM
  #38
Poolpilot44's Avatar
04 E55 AMG
Add another 04 E55 to the list! Mine has been doing it for about 5 months now. Ive replaced the expensive idler pulleys with the billet set, checked the power steering...No Dice.
Old Apr 19, 2015 | 07:20 AM
  #39
nafania's Avatar
e55 amg kompressor
Hello from overseas.
My name is Arseniy. I am from Kyrgyz Republic. I drive w211 e55 amg like everybody else here. I have read alot of posts here but didn't post much since language barrier.
First of all I want to Thank You everyone who is dedicated to this site and sharing his thought/results. Thank You guys.
My car has similar sound like OP. I uploaded a video to YouTube so other experts can hear and give us thought and clues where to and what to do next or just live with it. This is cold startup without any belts. At the end if the video my car tries to stall (you can hear how the motor goes up and down) i guess it is becouse the main belt is off. Sometimes next week going to shop to use stethoscope.
Any thoughts?
Old Apr 19, 2015 | 07:56 AM
  #40
SICAMG's Avatar
2005 e55 AMG
Sounds just like the oil pump. All belts off and noise still there? If you rule out the trans and all the noise is up front it is coming from the oil pump. You can actually here it cavitating at idle as its thinning the oil out when cold when you are standing outside the car. 0-30 oil for me in the winter is much more quiet than when I go back to 0-40. Even tried out Royal Purple today just to see and no change until its really hot from beating on it.
Old Apr 19, 2015 | 08:22 AM
  #41
nafania's Avatar
e55 amg kompressor
Monday / Tuesday we will try to illuminate transmission pump/tc or any other transmission related Parts.
For motor oil I use Motul 5-40 8100 X-cess. So if it motor oil pump i gues i will live with it until i get to the poit of replacing oil pump tensioner and then we will take a look at oil pump.
Thank you for quick replay.
P.S. SICAMG did you ever figured out or succeeded how to make our transmission to shift faster? I have read all your posts.
Old Apr 19, 2015 | 10:53 AM
  #42
SICAMG's Avatar
2005 e55 AMG
Yes. Took some time to understand what the PCM was trying to do all the time. With the help of my Xentry and getting into the transmission pids, f-ing with the valvebody and going back and forth with the TCU she's all set!!
Old Apr 19, 2015 | 02:43 PM
  #43
nafania's Avatar
e55 amg kompressor
SICAMG
Glad you got it working the way you wanted. Thanks for sharing.
Old Apr 19, 2015 | 03:55 PM
  #44
Max.H's Avatar
E55
All E55's sound like that. I think some of you guys might be chasing a problem that really isn't there. I have not hear any E55 that does not make those sounds at start up.
Old Apr 19, 2015 | 04:32 PM
  #45
SICAMG's Avatar
2005 e55 AMG
Not so much a problem. But can be real annoying when first started cold. It really sounds like crap for a car of this caliber. Anyone who knows me and the car never say anything but others are like what the hell is that!!! No worry's though. Nafina ...on the trans it was all about clearing the tcu adaptations and working in the valve body, in sport it's slightly above stock shifts but m mode nice and firm.
Old Apr 20, 2015 | 12:44 PM
  #46
nafania's Avatar
e55 amg kompressor
Little update from me:
Today i went to body's shop to use his stethoscope. It is confirmed 100% for oil pump, like SICAMG and MAX.H said.
Thank You to everyone.
Old Apr 20, 2015 | 01:58 PM
  #47
SICAMG's Avatar
2005 e55 AMG
Update for noise. My oil was only 200miles old but someone who races suggested Royal Purple 0-40 so I drained it "Mobil 1" and poured in the Royal Purple oil and it is much quitter now. Almost as good as the 0-30 oil for winter. Just some input.
Old Feb 27, 2020 | 11:23 AM
  #48
The Tinman's Avatar
Mercedes CLK320 W209 coupe
2004 CLK320 W209: For me the noise is only when the air conditioning system is active.
It seems the A/C compressor is ALWAYS on which is silly.
It sounds like the A/C compressor is cavitating internally but the Air is Cold.
How can I disable the compressor when I want only fan air? For now I just turn the whole thing off, it sounds like the A/C compressor is running even when the Heat is on maximum.
Old Oct 22, 2020 | 03:24 AM
  #49
pavelsmudla's Avatar
W211 E320
A/C compressor noise
Hello, I think it might be AC compressor pulley but not my case - I installed new one. I can stop that sound only if I switch all ventilating system off by button off. If I switch only AC off sound persist and if I put down serpentine belt it's same. I want also know if I can deactivated AC compressor by some fuse? Because I want drive a know if AC compressor make that groaning sound. Thank you. Pavel
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
