TRANSMISSION ERROR CODE
STAR DAS reports adaptation values good, trans fluid is good, but is reporting P2500 ERROR "TRANSMISSION HAS IMPERMISSIBLE TRANSMISSION RATIO".
Dealer blames upgrades TCU, doesn't feel a flush is worth wasting $, and doesn't take transmissions apart, just installs remans.
From what I've researched, if it's a conductor plate, I'll get other codes, etc.
Not sure about purchasing a valve-body on a hunch due to the cost.
Any suggestions?
If its your conductor plate, it will "usually" go into limp mode (2nd gear)and have codes for speed sensors (y3/6n3 etc..). Conductor plates are very common.
If you drop the pan and see metal, then you know you have a problem
I guess I'll drop the pan and see what I can see. I don't know what else to do at this point.
From what I've researched, if it's a conductor place, I'll get other codes, etc.
Any suggestions?
I then took it to a transmission specialist who checked it and said there was no metal shavings,and fluid was clean. I then had him change the conductor plate.
and i still had the problem. I then took it to a mercedes specialist and found that the ETC connector plug seal was leaking and filled the trans. control module with fluid I replaced the ETC conn. and instead of buying a new mod. I took mine out and sent it to a company call AES Automotive Electronic Solutions tele# 1-800-486-0922. for less then half the price. and i was all set.
Any suggestions?
I have a ml63 AMG from 2007
And have eror 1936 ( Y3/8n4)
Can you help me ????
