E55 weight
Old 05-17-2012, 11:07 PM
Forrest Gump 9's Avatar
shrimp boat
Originally Posted by e500slr
JESUS Why do these cars make so much torque (not a bad thing )? I mean the torque is so down low it's road shredding.
I don't know about you, but I rather have a little bit less torque and little more hp up top. Torque is what brake shiats.
Old 05-17-2012, 11:24 PM
chawkins2001's Avatar
2006 E55 AMG
One thing that generates tq is Cubic inches which the 5.4 litre has, and the second is changing out the crank pulley and not the blower pulley. If the pulley of choice to change was the blower pulley, I guarentee it would not make as much tq. Creating boost via the crank pulley produces a large increase in tq.
Old 05-17-2012, 11:46 PM
RedBullJnky's Avatar
you to Hate
I agree. But it also takes a good tune.
Old 05-18-2012, 12:00 AM
blackbenzz's Avatar
haters crazy
Why would it not make as much torque? Both result in spinning the supercharger faster. If the SC is spinning at same speed it shouldn't mater which pulley you changed
Old 05-18-2012, 07:56 AM
e55amgrocket's Avatar
Dirt Scooters
I think spinning the blower faster either way will make more power and torque. It's possible with the extra load of the larger pulley it could make a little more but im not sure on that one. The reason these cars make the crazy torque is because 331CI (almost 332CI) and a screw blower that makes its boost instantly.
Old 05-18-2012, 08:50 AM
2006 E55 AMG
it does make a difference, I am not sure why though. The reasoning stems from owning several terimators and my Lightning. When those cars first came out, guys were just changing the blower pillows to a much smaller diameter. Well that started causing severe belt slip, so for increased belt wrap, they started leaving the upper pulley alone, and changed the crank pulley. What happened was the following, changing uppers only to say a 2.81 resulted in 460/470 on a04 cobra car. Leaving the blower pulley alone and changing the crank pulley to say a 8lb lower would result in 440/540. I will find out why the distribution is so different for you guys.
Old 05-18-2012, 09:11 AM
  #32
Dirt Scooters
I know some tricks for belt slip so never had that problem
Old 05-18-2012, 05:07 PM
  #33
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Oh man, please do tell!
Old 05-18-2012, 07:50 PM
  #34
Dirt Scooters
Take the belt off and spray it with brake clean and the pulleys also. They get oily and causes belt slip. 2 things that work great to stop it if that dosent work is hair spray and the best is VHT.
Old 05-18-2012, 08:09 PM
  #35
e500slr's Avatar
2011 E63, 2013 CLS63
That's true because ultimately torque without power is no fun and useless but it gives you bragging rights you know. It's not just the number either, it's the curve and when the torque is at it's peak which in these cars is very low in the RPM range which means this car is an incredible daily driver, it doesn't scream and shout when driving normally but glides and is effortless and for me that's invaluable since I commute daily and the traffic is a *****
I'm surprised that the 6.3 Weistecs don't make more than these in torque I mean 5.4 is pretty big but not enormous. I mean Exotic's car is making over 700wtq for example which is over 900 crank tq and that's about as much as the Veyron makes (not SS) and that's a quad turbo W16
Quick Reply: E55 weight
