engine oil dipstick grommet replacement
Old May 21, 2012 | 11:36 PM
tri-star tech's Avatar
2004 CLK55
Originally Posted by Alps
i stand corrected, it doesnt come from factory but the additional tube is added by the workshops sometimes to enable a manual dipstick to be used.
No additional tubes are added. They're both there from the factory.
Old May 22, 2012 | 02:28 PM
£ C43 £ AMG £'s Avatar
E55K AMG
Originally Posted by zkeller
Can someone elighten me as to how to remove the engine oil dipstick? It will not pull out of the engine. It seams to be stuck on something in the pan.
I need to replace this grommet as it is leaking pretty badly. Please do not tell me the oil pan needs to come down.
The tube goes quite a way in at the bottominto the engine
The upper sump needs to be removed (subframe etc) or I think you can remove the supercharger and get it out that way or just put sealer around the gromet............................... or cut the bracket off that is preventing the tube from sliding out next to the T/B, but if you do that you will not be able to secure back properly.
Old May 22, 2012 | 02:46 PM
Roverron's Avatar
ML63
Gasket Guide tube part number #95 looks like what seals it and holds it place dealer part number is A1120180080
Old May 22, 2016 | 10:39 AM
Pinoi Ryder's Avatar
2003 E500 Sport
has anyone able to remove the dipstick tube for engine oil?
Old May 24, 2016 | 01:45 AM
Papieye's Avatar
W211 E55 AMG
Yes I have, but i hade the engine suspended and the subframe out of the car. Lower and upper oilpan removed aswell. It's impossible to get back into the grommet if you do remove it. I had to cut it in half, inser lower half of tube into the grommet and then slide a rubber hose over the dipstick tube and two hose clamps to attach the piece of the tube above
Old Jul 25, 2020 | 10:21 PM
Sandeep Singh's Avatar
2004 SL55
@ZKeller . did you ever get this resolved . I'm in the same boat at the moment.
Old Jun 6, 2024 | 02:05 PM
  #32
JuniorG23's Avatar
2013 Mercedes benz C250 w204 Sport sedan avantgarde
Had this problem if u didn't fix it I got you very carefully use some jb weld extreme do a tear drop size drop on the top part that's broken of the stick and carefully I repeat carefully put it to the lipstick end stuck inside let it sit overnight and u should be able to pull it out that way I did it flawlessly easy peasy lmk how it goes
Old May 5, 2026 | 09:48 AM
  #33
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Geezuz just tried to seat this tube into / through upper oil pan and omg its friggin impossible to get back into position … lower and upper oil pans have just been reinstalled 🙄
Any ideas?
Old May 5, 2026 | 10:40 AM
  #34
stevebez's Avatar
Any ideas?
Old May 6, 2026 | 11:36 AM
  #35
bobgodd's Avatar
2004 E55
Any ideas?
This is one of the hardest jobs I've done on this stupid car lol. I ended up using a tube cutter, cutting the dipstick tube into two halves, inserting the lower half with the new grommet and then using hose and hose clamps to attach the two halves back together. I simply could not get it back in otherwise.
