STOCK E63 "13.091 @109.19mph" Is this slow??
Old Jun 6, 2012 | 11:07 PM
nysid2007's Avatar
08 E63 AMG
Hey guys
Just got back from the strip and did 13.091 with ESP on .
Is this slow ?? or within the right range for a stock.
So far my car has drop in filters , sec cat delete with X pipe and resonator
delete with straight pipes.
Stock 18inch wheels and stock muffler .
Attached Thumbnails STOCK E63 "13.091 @109.19mph" Is this slow??-4-.jpg   STOCK E63 "13.091 @109.19mph" Is this slow??-lef-13.09.jpg
Old Jun 6, 2012 | 11:14 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Depends on weather conditions, elevation and track prep.. Post the slip though as that will tell some of the story
Old Jun 6, 2012 | 11:17 PM
RedBullJnky's Avatar
you to Hate
This^^^^ and have you ever been to the track before? It all plays a part. So don't ever feel bad about any times.
Old Jun 6, 2012 | 11:21 PM
AWOL's Avatar
e55
I would expect an average of 12.5@~112-113 for the e63
Htownbrother's Avatar
'14 Mustang GT, '13 F-150 SuperCrew EcoBoost, '05 SRT4, '04 E55 AMG
Yep, post your slips. What did your 60' look like?
Old Jun 6, 2012 | 11:55 PM
moosejaw's Avatar
none
What's the elevation over there?
Did u leave your golf bags in the trunk?
Old Jun 7, 2012 | 01:43 AM
cahiil55k's Avatar
Did you let off the gas too early or mess up on manual shifting?
Old Jun 7, 2012 | 02:18 AM
nysid2007's Avatar
08 E63 AMG
will post it soon ~ check it out and let me know what u think. Thanks.
Got it ~
Are you sure about that???? My car is in pretty good shape.
Looks like a e63 ~ what you mean by look like ~ color??? its white
No ~ do you leave yours always in the trunk?
I didnt even bother with manual , My tranny was in "Sport" mode. When I use
manual mode it always hits the rev limiter even with shifting around 6k rpm.
Old Jun 7, 2012 | 02:34 AM
moosejaw's Avatar
none
Your 60' times are horrible
You could easily knock off a few tenths off by practicing
I think your car is fine
Did you read the "drag racing how to" by loungn14?
Old Jun 7, 2012 | 02:37 AM
nysid2007's Avatar
08 E63 AMG
No , I will check it out ! Thank you for the tip !!
But back to my question ~ so my time is considered normal ??
Old Jun 7, 2012 | 03:21 AM
Ryououki's Avatar
2005 E55 AMG
Your time looks fine. Get more practice and you'll be in the 12s.
Old Jun 7, 2012 | 03:24 AM
BBBSS's Avatar
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
Your 60 foot times are slow. A good solid launch should probably get ylu down to 1.8 or 1.9. Every .1 you shave off your 60 foot typically will shave .2 off your elapsed times.
Turn off traction control, warm the tires up/clean em a bit with a lil burnout if the car allows it and play with how you launch the car. You need to learn to get off the line harder and without spinning the tires too much andbyour times will start to drop.
Old Jun 7, 2012 | 03:34 AM
moosejaw's Avatar
none
Your times aren't ideal for a e63
Just for comparison, your time is slightly SLOWER than a stock c55 I know of that consistently runs 13 sec flat. Your trap time seems okay
Do you have the performance package?
Old Jun 7, 2012 | 03:35 AM
nysid2007's Avatar
08 E63 AMG
Like you said I need to figure out a way to launch with out wheel spin.
Thank you for the info !!
Old Jun 7, 2012 | 03:37 AM
nysid2007's Avatar
08 E63 AMG
I see ~ better practice on my foot time and see how much I could shave it
off.. Thank you .
Old Jun 7, 2012 | 07:13 AM
GT-ER's Avatar
2005 E55 AMG
Take off the traction control, launch better and watch your car do 12.7@111mph.
Old Jun 7, 2012 | 07:28 AM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
My car does worse with traction control on, it will start to spin then ESP will kick in and it will fall on its face and then I will run 3 or 4 tenths slower. I have always been able to do better 60ft times by trying to feather the throttle off the line with ESP off (we are talking on street tires).
Find out how good the track is sticking depending on their track prep and give it more and more throttle to where you may spin a little but are moving forward rapidly. Should be easier to do with an E63 too since you don't have the huge torque down low like a modded E55. You could easily knock 4 tenths off that time.
Old Jun 7, 2012 | 09:16 AM
Jimshorts's Avatar
'05 SL65, '13 FX4 Eco
I usually keep t/c on and just goose it out of the hole. If t/c goes off then I know I pushed it too hard but thats just me.
Work on your 60fts and you will definitely cut some time. Everything depends on the 60ft if you ask me. On 85-90 degree days my car will run in the 13s at 110ish. On a cold 55-60 degree day its an 11 second car. Weather has a huge impact on these. At 75 you should be able to see some mid to high 12s around 110-113.
Old Jun 7, 2012 | 10:36 AM
moosejaw's Avatar
none
Was this track @ Sonoma/Infineon?
I looked at dragtimes and all the cars listed at the track run consistent times.
So you need to def improve your 60'. You should be in mid 12's.
Try feathering the throttle at start and then gradually easing into WOT.
Reading Jake's sticky should help you
Old Jun 7, 2012 | 11:22 AM
Kreuzfeuer's Avatar
SRT-6
Agreed 100% with the others, the times aren't horrible you just need to nail the launch.
I was at Beech Bend this past weekend with Deuce-Zero and his E63 was anywhere between 12.6XX and 13.1XX, depending on his launch. Didn't help that he was on Blizzaks, haha. Love those cars, they sound superb.
Old Jun 7, 2012 | 12:55 PM
BenzCLS06's Avatar
CLS55
Ur ride is fine. U just gotta learn how to launch. It takes a lotta practice so just keep tryin and you'll be fine. I remember my first few experiences at the track were discouraging. You learn a lot bout ur car when ur at the track and once u start nailin those 60 fts, ur golden. Good luck!
Old Jun 7, 2012 | 03:24 PM
deuce zer0's Avatar
E63
got some new tires today with some more meat on the back instead of the winter 245's. i'm ready to go back! you going to run your car anymore this summer?
Old Jun 7, 2012 | 03:46 PM
Kreuzfeuer's Avatar
SRT-6
Awesome, I was wondering when you'd ditch the winter meats LOL
Once we get into the extreme heat, Steve and I won't be running anymore until fall. DA is simply too high and there's no point in beating on the cars to run worse times. By fall, I will have ditched the slow intake and will have the NW back on, plus some other goodies. If I can nail another 1.8 60' on streets, I'm hoping to see 12.1XX, at which point I'll be a happy camper. Steve wants me to run drag radials, a guy in FL with my exact setup (plus DR's) is running 11.8 consistently in the 1/4 mile... but as discussed at dinner the other night, he's about 60# lighter and has several more passes under his belt.
Personally, 1/4 mile is fun but my real fun is had when you hit 100 before a chicane and then turn the wheel
We'll give you a heads-up if we get another 60° night in the next month or so... but I don't think we'll have too many more of those unfortunately.
Old Jun 7, 2012 | 03:53 PM
nysid2007's Avatar
08 E63 AMG
Yes it was at the SONOMA . Thank you for all the feed back !! I will post some better slips next week!!
Thank you . Mine sounds a bit quite . Compare to other AMGs including 55s
I have a 3 inch X Pipe with large openings and that took away a lot of sound.
Thank you . Will post some better slips next week . !! I might get a set of
Nitto NI01s to help my launch ~
Old Jun 7, 2012 | 03:56 PM
deuce zer0's Avatar
E63
I didn't ditch them. Just setting them aside for a more appropriate time, like that time ever comes in our area...
