Testing the corn (E85) @ the pump
Old Jun 22, 2012 | 09:27 AM
chawkins2001's Avatar
2006 E55 AMG
Decided to test the E85 at our local gas station to see what the actual octane was of the corn.
You fill the tube up with distilled water up to the line at the bottom, then pump E85 to the line all the way at the top. Turn the tube upside down several times, and let the corn and water seperate. The seperation line will tell you exactly what the octane actually is. Best part about it is, cost only $3.19/gallon
Based on the results of the test, it looks like the summer blend is E90
Old Jun 22, 2012 | 09:30 AM
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
Nice, that is some fairly potent stuff
Old Jun 22, 2012 | 10:02 AM
cij911's Avatar
one car at a time
You can also use a Zeitronix ethanol analyzer as well....IMHO, I would recommend tuning on the low side of e-xx based upon your area. If your tune is for e85 and you run e50, you could have issues....
Although e85 is great stuff, I would not recommend it for a daily driver as the mpg are worse than standard pump....
Old Jun 22, 2012 | 11:40 AM
kompressede's Avatar
Sold - 05' E55
And it takes a few minutes to run decent on a cold start up, at least with the S4 it does.
Are the inside of your tail pipes clean too?
Old Jun 22, 2012 | 01:58 PM
2006 E55 AMG
100% correct man Must be a corn thing.
Old Jun 22, 2012 | 04:44 PM
RedBullJnky's Avatar
you to Hate
Very nice sir! I'll be doing the E85 conversion right after I hit 10 seconds.
Old Jun 22, 2012 | 04:55 PM
2007 6.3's Avatar
2007 E63 AMG
What does it take to convert to E85??
Is this just a E55 thing or can E63 guys plsy too??
Old Jun 22, 2012 | 04:59 PM
FT-Performance's Avatar
Former Vendor of MBWorld
FTP-E55///AMG
Tester looks Familiar Craig
Old Jun 22, 2012 | 05:12 PM
Firechaser's Avatar
2008 GL550
The winter blend works just as well..I was concerned years back about the "E70" but it made no negative difference at all.....the stuff just works! Boost freely!
Old Jun 22, 2012 | 06:39 PM
Toadster's Avatar
2005 E55 AMG
smells like in here
