One piece C63 rotors on E63?
Old Jun 28, 2012 | 12:33 AM
Ben Z.'s Avatar
E46 M3
Hey guys, it is about time to replace the front rotors and pads on my E63. I've been looking at the Evosport and Racing Brake options, but also noticed that the C63 guys were talking about how cheap their non performance package one piece rotors have gotten. Now, correct me if I'm wrong, but the two piece performance package brakes on the C63 are the same as the ones on the E63. Does this mean the single piece rotors can be used on the E? I wouldn't mind saving several hundred dollars for slightly more weight and reduced performance on a pretty softly sprung daily driver...
Any input would be great. Thanks!
Old Jun 28, 2012 | 05:03 PM
Ben Z.'s Avatar
E46 M3
Anyone? Could save a lot of W211 owners some money..
Old Jun 28, 2012 | 08:22 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Yes the front rotors would work.
Old Jun 28, 2012 | 10:01 PM
Ben Z.'s Avatar
E46 M3
Awesome, thanks!
I'm assuming that they will be a direct replacement.
Has anyone tried running the one piece rotors on the E63? Any noticeable negative side effects?
Old Aug 22, 2012 | 12:10 AM
pnoyworx's Avatar
10 E63, Sold -07 E63
So just to double check, you are confirming that the C63 rotors work on w211 e63? Because I'm ready to buy.... Any year C63 or specific? Thanks.
Old Aug 22, 2012 | 01:32 AM
Arnee's Avatar
Cayenne GTS, Cayenne Turbo
subscribed
Old Aug 22, 2012 | 02:02 PM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I am also in. I need need new fronts also
What yr C63s solid will fit the W211 E63s????
Direct bolt on.....also
Old Aug 22, 2012 | 04:45 PM
2007 6.3's Avatar
2007 E63 AMG
Sub'd...
Old Aug 22, 2012 | 04:50 PM
Arnee's Avatar
So I don't think this is any different than using 1-piece E55 rotors on the E63.
I'm still leaning towards the 2-piece rotor from EvoSport but I'm just curious to see about the W204 C63 rotor compatibility.
Old Aug 30, 2012 | 04:13 AM
pnoyworx's Avatar
no certain answer from anyone? Anyone done this at all? Or is this all speculation based on same measurements of the rotors data's for the front.
Old Aug 30, 2012 | 10:55 AM
Mr-Uli's Avatar
2001 nogaro s4 s1 (sold), 2001.5 casablanca white s4 s3++ (sold), 2006 e55, 2011 pilot, 2011 edge
on previous cars i've dealt with irotors and had good experiences. i'd imagine they have stuff for our cars as well
Old Aug 30, 2012 | 09:02 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Originally Posted by Ben Z.
Awesome, thanks!
Unless you are doing track days, I would consider the down sides minor or almost neglegible (sp?)
Slightly more unsprung weight is one.
More heat to the wheel and hub (again, if not track use, not enough heat to matter).
Much more money in your pocket... oh, wait, that is a good thing
Old Aug 30, 2012 | 11:12 PM
pnoyworx's Avatar
So does it fit properly?
Old Aug 31, 2012 | 07:50 AM
jayjmuir's Avatar
2007 E63 AMG (Dubai), 2009 BMW X5 4.8i Sport (PA)
http://www.carpartsshed.com/Catalog/...2008&Part=Disc Brake Rotor&sModel=Base&engine=8 Cyl 6.3L
http://www.parts.com/parts/2008/MERC...omponent=ROTOR
Are these what we are talking about? This would certainly save a lot of money for non-track driving people. If that is accurate, you would be looking at total brake job for the cost of one E63 front rotor. Plus, for that price, you could add some really aggressive pads and probably not lose any braking performance - not expert though. I'll defer to Jon on that one.
Old Aug 31, 2012 | 12:12 PM
pnoyworx's Avatar
Just need someones confirmation that they witnessed or actually has done this. If it does, there is a whole lot of options available for c63 rotor in the 1pc dept. I may just buy the OEM C63 1pc rotor and try it, my parts guy said I could try and return if it does not work. The real concern is just the offset of the rotor, the rest of the specs are the same. diameters x thickness are the same for both.
Old Nov 14, 2012 | 05:06 PM
Biffed's Avatar
2007 E63
Did anyone ever verify if this will work??
Old Nov 14, 2012 | 06:48 PM
pnoyworx's Avatar
I was waiting on this too, you may be able to verify by checking Racingbrake part numbers, when I look up rotors for the E63, it shows the same part for C63... but no solid confirmation on anyone doing this yet as far as I know.
Old Nov 14, 2012 | 09:04 PM
Biffed's Avatar
2007 E63
Ok good to know that it is not a dead thing and may still be a possibility.. I need to do my rotors and brakes and there is a very good possibility that I will be selling it and picking up the Panamera so wanted to keep cost down.. I still love this car though and have considered keeping it to mod the $%#@ out of it for a fun weekend car.. If I do keep it I am going to go with the Evosport rotors as I have heard nothing but great things about them.
Old Nov 17, 2012 | 01:14 PM
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Roger. Yesterday I emailed them for confirmation on the rotor ring they show 14041-311K-01. No response. This came up on their site when search word C 63 was used. However, now I suspect the 355 mm may be too small dia. I am just starting this search so will try to soak up this thread and others. If I find anything worth while, will advise. (CENTRIC shows good drawings on line and @ Rock Auto-with dims).
Old Apr 15, 2014 | 07:33 PM
Wakeby Fire's Avatar
2008 E63 Flint Grey
I've used c63 rotors on e63
I used 2008 c63 rotors on my 2008 e63 and they were a direct fit. Honestly I can't tell the difference from the Evosport rotors that I had on before, if anyone is still interested. I also use EBC red brake pads in front. They work great and a lot less brake dust.
Old Apr 15, 2014 | 08:08 PM
deedubb's Avatar
2007 E63 AMG
YES!!!
Old Apr 15, 2014 | 11:00 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Nice
Old Apr 16, 2014 | 10:53 AM
deedubb's Avatar
2007 E63 AMG
Maybe someone can answer here... If the stock front rotors on an e63 are 2 piece, can we just buy replacement rings to save some coin? Or do we have to buy the whole setup (hat and disk)? If you can buy just the ring, where can I source replacements?
Old Apr 16, 2014 | 03:51 PM
You can not buy replacement rings for the two piece OEM.
You can for the racingbrake setup.
If you do not track, buy the less expensive one piece.
Old Apr 16, 2014 | 06:21 PM
baldmike73's Avatar
advantages of E63 2piece vs C63 1piece - please chime in
