NITROGEN VS COMPRESSED AIR
DG
Basically check your pressure occasionally and save your money.
PV=NRT
P=Pressure
V=Volume
N= number of moles of gas
R=reynolds number
T=temperature
Now with that being said, there is 1 advantage to nitrogen, which is a dry gas, think no water here. So if you left your tires on for about 5-6 years, your rims would still look good
Would I ever do it, HELL no, save the money.
... Makes my car definitively lighter and rear suspension works less, so my rear tires last longer.
PV=NRT
P=Pressure
V=Volume
R=reynolds number
T=temperature
Obviously, if you used hydrogen or helium, you get problems with it leaking out. But dry air should work fine.
Your home low end compressor does NOT eliminate the moisture. But I use it anyway. Unless you are doing a track day it likely does not matter.
ANY gas will be effected the same my friend. You can NOT change the laws of physics.
The ONLY way that air would be effected more is IF there was a high enough water concentration, and IF you made you rims hot enough to boil the water out of the air. This just isn't going to happen on a street car, EVER.
One last time:
PV=NRT for ALL gases and mixtures of gases.
One last time:
One last time:
