Slight hissing sound under WOT...?
Old Jul 19, 2012 | 04:52 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
OK so I got this issue, now I dont know if its something new or mbe had not noticed before. Sounds like a boost leak and I've trippled checked the bolts / gaskets etc.
Seemed to arise when I removed the S/C phenolics... mbe its a misaligned / damaged gasket. I reused the old ones ? Anything else come to mind?
Mbe its just how it sounds now ...
Old Jul 20, 2012 | 04:30 AM
stevebez's Avatar
Anyone ?
Hear similar? Is it normal ... ?
Change gaskets out ?
Old Jul 20, 2012 | 09:54 AM
cij911's Avatar
one car at a time
It sounds like a boost leak and since you mentioned changing gaskets - start there....pressurize the system if you want to be 100% sure...
Also, you posted a change in your exhaust (in another thread).....Are you certain you don't have an exhaust leak (pinhole leak from a bad weld) ?
Old Jul 20, 2012 | 10:48 AM
stevebez's Avatar
The exhaust I think is ok as its more a hiss than a tick, and it was there before I did the mid section rework, and still there now.
Might be one of those semi transparent breather tubes that either dislodged or bust
And then it could be the gaskets. They have had a few re-re's in their life.
Old Jul 20, 2012 | 10:54 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Get the MAP from the OBD2 port to confirm if you have boost loss
Old Jul 20, 2012 | 10:55 AM
SavMan's Avatar
2004 E55K AMG Wagon
Good point, you might want to check the flexi's you had installed
Old Jul 20, 2012 | 12:13 PM
Forrest Gump 9's Avatar
shrimp boat
The easiest way is spray some carb cleaner into the suspect leaking areas while the engine still running. If the rpm drops then you have a leak, if not you're fine. Good luck.
Old Jul 20, 2012 | 01:06 PM
cij911's Avatar
one car at a time
Not exactly...sometimes the leaks are only seen under boost (vs. vacuum)....Which is why I suggested pressurizing the system....
Old Jul 20, 2012 | 04:32 PM
stevebez's Avatar
thx guys...
Old Jul 20, 2012 | 09:44 PM
Celicasaur's Avatar
W212 - E63 AMG
I'm willing to put money on it being an exhaust leak. Take it back to that exhaust shop, put it on the ramp, start the engine and feel around the flanges where they worked on/spray liquid. I'll bet that's the problem.
