Had Both Belts Replaced @ 75K Miles Now The Squeal Badly at Startup for ~5 Mins
Old Aug 7, 2012 | 09:48 AM
alextaylor29's Avatar
2004 E55 AMG
Peeps,
Quick question for you. I had both the main belt and S/C belt replaced about a month ago when I had the beast in for regualar service. Directly after the install the belts squealed pretty badly but as the car warmed up this went away.
I talked to Charles, the master MB Mechanic at AutoHaus in Scottsdale who did the work and he said this should go away in a week or so as the belts were simply new.
Well a month later (and I drive 100 miles a day too and from work), they still squeal pretty badly at start up, even when in park. After about 5 minutes this goes away completely.
Anyone have this issue before? My uneducated guess is either the belts weren't tensioned enough or their just a tiny bit off when it comes to size?
I park in an underground gararge so it's embarrasing frankly as I leave for work and my car is squealing like a stuck pig echoing like crazy as I drive up through the levels.
Thanks!
Alex
Old Aug 7, 2012 | 09:54 AM
Roverron's Avatar
ML63
Did they replace with the stock belt?
Looks like you have a 180 on your car I think that takes a different belt.
Old Aug 7, 2012 | 10:03 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Check your idler pulley`sfor bearing wobble (with belt off) and you may also have a bad belt tensioner. Usually the double idler pulley`s go bad on the passenger side.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 7, 2012 | 01:43 PM
2004 E55 AMG
Thanks guys! Yes I have a 180mm pulley but Charles made sure he got the correct size for the 180mm size.
Old Aug 7, 2012 | 02:25 PM
Forrest Gump 9's Avatar
shrimp boat
I have the same problem. On my car it was the serpentine belt. So I replaced it with a 1/2 inch shorter belt. Haven't heard a thing since. I'll get you the part number tonite.
Old Aug 7, 2012 | 02:27 PM
novae500's Avatar
W211
i had the squeal and would go away after a few minutes. But did notice that the double pulley was throwing grease and was not looking to good. Ended up replacing it w the ASP pulley kit.
Old Aug 7, 2012 | 05:19 PM
2004 E55 AMG
Thank you again. The part number would be handy as I have the part numbers from the belts he used. My guess is the belts are just a tiny bit too big so they slip when their cold and only when their cold.
Thanks!
Alex
Old Aug 7, 2012 | 10:39 PM
mrweelr's Avatar
2016 CLS63S AMG, 2017 GMC Sierra Denali Ultimate, 2019 KTM 1290 Super Adventure R
I have the exact same problem. Just installed the smaller S/C clutch and 3-piece ASP pulleys along with a new shorter "Green" belt Shardul recommended and my damn belt squeals like a MF for 5 minutes after I start the car. It's embarassing leaving the house and leaving work. I tried spraying the belt with some of that stop squeal stuff but it didn't do anything. The new shorter belt is super tight, I'm hoping it just needs to wear in or something. I didn't change the stock accessory belt, but it didn't squeal before the ASP pulleys went on.
Old Aug 7, 2012 | 10:41 PM
ffordstim's Avatar
bmw
Old Aug 7, 2012 | 11:05 PM
shrimp boat
Dayco 5060960, this belt is .6 inch shorter than stock. It cured my squeak problem.
Old Aug 8, 2012 | 09:53 AM
2004 E55 AMG
Thanks for this. Just confirming though, you have a 180mm pulley as well?
Thanks!
Old Aug 8, 2012 | 10:32 AM
shrimp boat
Thanks!
Yes, I do have the 180mm pulley too, but that shouldn't matter since this is the serpentine belt, not sc belt.
Old Aug 8, 2012 | 06:57 PM
2004 E55 AMG
Gotcha, thanks!
Alex
Old Aug 9, 2012 | 08:34 AM
2004 E55 AMG
All,
Circling back here and checking the belt number on my receipt he used belt number 5060970 which I believe is probally .6" to long, hence the slipping/sqeeling.
So thank you for helping me solve this!
Alex
Old Aug 9, 2012 | 08:40 AM
2004 E55 AMG
Yeah for mine they never squealed until I had them replaced so jut following the logic here, it probablly means the belt was just a hair to long/lose.
My $.02.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
