615HP/720 TQ: What will new motor do?
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
1. Quoting converter flash TQ is just a lame way to make the uninformed go WOOWWW and the informed think you're a clown. ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
2. Here is a whole article on how easy it is to play with dyno numbers if you want it to read higher then it should.
3. MPH at the track along with a few factors about the car will show the power you make, and you can't fake that.
http://root.wip.gmhightechperformanc...el_horsepower/
Originally Posted by Exotic-metal55
The peak torque is a legit reading for that rpm on that motor
Guys, the graph is a perfectly normal graph for an automatic car and torque converter flash is not decpetive or fake. If the car could be stabbed at 1600 rpm, then you would see a larger / longer torque curve, until it couples and levels out the Torque average. The more power you put to the converter, the more torque multiple raises. Again, normal graph just higher numbers than many have seen on these cars. I have posted tons of graphs from the same dyno and many others have done the same. The car will create that much real Torque at launch and then average out to 640 down the track or so. Again, all normal graphs and curves for an automatic.
719 TQ t is a peak torque number and is consistent ratio over the HP , as compared to less HP cars (about 100 over hp or do the %). The converter does not lock up at WOT, it is basically a fluid coupler but that is a whole other topic. I always post all my graphs, times and motor info over the last 4.5 years of this.
Another thing you claim that your peak number is what the motor should be making at that rpm and that's flat out wrong, Torque is a function of BMEP and will generally peak in the high 3K low 4K range with a gas motor NOT 2600rpm
if the car really made that torque it wouldn't have **** it's self and lost 100ft/lbs in 100rpm
Exotic-Metal - What a bunch of smoke and mirrors and trying to impress the uninformed or naive.
For the record you have grenaded at least two engines but have the bravado to criticize Mercedes and even Kleemann in the past. MB spends almost $2Billion per month on R&D and I have yet to see a stock 500hp 55K fail (even with high miles), so evidently they have done their homework.
In one breath you talk about twin turbos, next minute you talk about your lofty hp goals and a warehouse full of AMG engines and parts with no real details or depth.
At one time you had a decent reputation and your posts generated good discussion. However it is very apparent after the Red Tooth Racing pulley failures and avoidance or admittance of fault including the vague details of your "Race Ported Heads" and other so called performance parts that you and your friends pedal and conveniently not providing any emperical data to substaniate the parts or the price, members on this board (myself included) have realized very quickly the truth. Your credibility and reputation has taken a huge hit and fate sealed. The high regard and trust that you once had on this board and with members is certainly no longer there.
I am prepared to eat a huge slice of humble pie so feel free to prove me wrong at any time and with that said, I hope you get your car running reliably again.
#33
Dirt Scooters
If we go on torque spikes then i've made 780 ft/lbs all motor, 740 ft/lbs the first time Jerry even tuned it and had a spike in the middle of the run and i've hit over 1000 on nitrous and had a graph the night before the pulley incident that wasn't a spike that (sprayed at 3000rpm) and torque hit 927 ft/lbs and was over 800 ft/lbs almost the entire run. Point is this is exactly why dyno numbers don't really matter and can be cheated so easily. Track numbers tell the story.
#34
PLATINUM SPONSOR
Mahle supplied the custom total seal rings for the Alusil bore , as part of their piston E55 piston package. Have you used this set up in the past?
Why don`t everyone post up their dynos and we can set up posting rules to meet everyones dyno/ hp and TQ needs, since dyno`s seem to be such a touchy subject.
Most stopped sharing dyno information years ago (Like Bassn and others), as it all became to controversial. Dyno`s can supply great info, if we all work together to share the info.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#35
#36
Dirt Scooters
Thats why i don't post dyno sheets although a few on here have seen some of them. Dyno operators can make a car have higher numbers very easily. That's why its honestly pointless to post dyno sheets or numbers.
#37
Ducati
At the last meet I went to in SF/Bay Area, I met a gentleman in a pewter E55. Had everything done to it - killer chiller, giant crank pulley, milled supercharger pulley, headers, built trans, lsd, and some other stuff....
He pulled out a 10.4 slip and a video of his run.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I invited him onto this forum, but at the time, he said there was too much political BS/mud slinging between the members.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#38
Dirt Scooters
This....
He pulled out a 10.4 slip and a video of his run.![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
I invited him onto this forum, but at the time, he said there was too much political BS/mud slinging between the members.![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#39
V12-Biturbo
a far, far, cry from legit 615 rwhp
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
#40
V12-Biturbo
#41
Received 1,065 Likes
E55, GLS450, GL63, GLE350
Why would Mahle supply an aftermarket ring when they make their own?
#43
Dirt Scooters
That right there is the exact reason i was so pi**ed when the car broke. The pass it threw the blower belt was the fastest until that point i had and was already over a tenth faster to the 330ft than the 10.51 pass and i had full intentions to cool the car down after that pass and try to make a full nitrous pass and *possibly* break that 9 second barrier. Hopefully i can break that next season.
#44
PLATINUM SPONSOR
Yes, but, they were not supplied by Mahle. The rings scored the cylinders. Maybe they changed the metallurgy and they are now truly compatable?
Either way, don't be surprised if you have an engine that goes through oil very quickly or blows smoke on acceleration. I've heard they can also cause piston flutter but I have no direct experience with that symptom. I know Total Seal lists them as compatable with the Alusil bore. Some have had good luck but others not so lucky. I would not use them again.
I made and re-posted my dyno that was posted a year and knew that the few members that do not get along with me would come to twist words, numbers and info around , as it has been a slow summer for some. Unfortunatly, it is as one member hinted, a big loss to the forum to have veteren members bashing each other and distorting the intent of the topic. yes, I also have responded to the bashing at times with the same immature words and langure, that is not my stlye or enjoyment. Some of the bashers are even using alter IP`s and screen names to fuel the fire.
I post my mods, track times, Texas mile times , engine builds, any new research and ways to improve are cars, as I gather inforamtion. Therefore, that makes me a BIG moving target for haters and lot of info for them to alter, twist and have fun with. All my dynos are done at LSXdynotuning by a member here named 98Aggie, who owns and runs the dyno. This info is also posted all over. Over 500 members here and on other much, much larger forums (all owned by interent brands) also dyno at this dyno. It is very well known and respected place to dyno to tune on, hang out and get tech help at. As the name implies, they do a lot of LSx cars and have a large enough dyno to handle LSX cars making well north of 1200 hp.
I posted my peak dyno / HP numbers and always post the sheet that goes with it. At times I get PM`s and ask for my dyno sheets and I am happy to send that over. That way , all can see the curves and where the numbers come from, since we all have different ways to use the info. Since I am on the dyno to tune, I always try and stab it at 2300 rpm each time, make sure my IATS are about 80 deg each time,,, so all my info stays consistent. Very few people do this and then spend a lot of money second guessing. This thread is about my personal car and info about the car`s build , potential new power goals, the parts to get it there but has gone off topic and crashed along with the info that could have been shared with it. With a few of the members around this forum, you can see why so many are not posting, sharing thier new mods and thier dynos anymore. I will still keep posting my info, but up the the members if they want the threrads to keep getting crashed and loose the info that comes from positive threads of give and take and create.
__________________
www.ultimatepd.com
www.ultimatepd.com
#46
The stock e55k blower will not flow enough volume to make the claims in the thread.All of my dynos have all the info on the bottom of the sheet,how hard is it to post a sheet with the conditions and correction factor used?
becasue maybe its a wild C/F to bloat your numbers?I have asked this before and never got a responce and 10 bucks says If I used you c/f I will make 600whp too.
this thread and its title is nothing but bragging and you even post the fake torque numbers in your sig.
trap 130+ and ill believe you are making 600whp and when you get your new engine up and running find a dynojet and post a dyno sheet were we can all compare too and let all the info be on there instead of bluring it out
I dynod the same day as a brand new gt500 and it made 596 whp and I made 499 and there is no way in hell I can make up 100whp with adding more boost and heads to catch up to that car on a properly dynod run.we could ice the car down and put the temp sensor in the engine bay and get a wild c/f and make a glory pull but wtf is the point of that?
On a proper setup dynojet(that read hi)a 55k will make max 560-5whp with every possible thing you can do to the car,maybe a few whp here and there but Iv seen 3 or 4 maxed out dynos across the world and they all seem to max out around 560whp on race gas.
now you make a thread about making 700rwt and breaking 610whp with a dyno sheet that looks like its made in paint shop where your torque peak is and no correction factors shown or temp and humidity shown.
you are the reason people dont post dynos anymore
#48
Taking 16 lbs off the rotating mass will go along way towards saving parts and making it rev easier!
Also, whatever you can do to keep valve float (you said you have stout springs) and a stable valve train will help longevity too!
#49
3-five-five/ TUNDRA/ 07 997 cab
I can't believe you're a SPONSOR here
What's w/ALL the *****-envy-Masterwhacking talk![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
PS if you don't like people knocking on your Dyno's? Don't Gush on "Ohh I made 612rwhp 719rwt" when in reality you make much, much, less thru out majority of curve where we ALL agree your actual #'s lie (actually even lower as that DD is setup to loonsville)
LOL, damn I miss this place!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
