accurate data logging...
Old Aug 31, 2012 | 10:17 AM
Toadster's Avatar
2005 E55 AMG
Originally Posted by lowprofile
Link not working.
So which parameters were you logging aside from what you shared?
There've been 8 viewers so far - no preview you have to download and look at it.
I'm using the default PIDs that Dash Command found. I just recently removed some of the Speed & Mileage sensors because I'm not looking at logging MPG (I already do that in a more granular fashion)
Old Aug 31, 2012 | 10:30 AM
lowprofile's Avatar
E55
Well, that was it, I wasn't about to download anything.
I'll just assume you were datalogging more parameters at the same time, aside from the four you displayed.
Old Aug 31, 2012 | 03:03 PM
Toadster's Avatar
2005 E55 AMG
the only persistend PIDs are:
SAE.RPM
SAE.VSS
Old Aug 31, 2012 | 11:12 PM
cij911's Avatar
one car at a time
I had trouble with the download earlier today....I'll try again tonight
Old Sep 1, 2012 | 12:31 AM
Toadster's Avatar
2005 E55 AMG
the lgf format is junk IMHO, you really have to break it out into a CSV to look at the info logically...
Old Sep 2, 2012 | 10:45 AM
FASN8N's Avatar
CTSV/6sp Grocery Getter
I am looking into using the kiwi/dash command setup with my iPhone.
Any positive/negative comments on using the kiwi Bluetooth instead of the kiwi wifi?
Old Sep 2, 2012 | 11:06 AM
  #32
Toadster's Avatar
2005 E55 AMG
I was initially going that route, but found the WiFi version for $60 on Craigslist - couldn't pass it up
Pretty much depends on the medium you're going to use - if your device has bluetooth or WiFi (or both?)
Old Sep 2, 2012 | 11:58 AM
  #33
FASN8N's Avatar
I just did not know if bluetooth would be any more accurate/faster than wife?
As you know, the iphone 4 has both wifi and bluetooth capabilities. I guess it just depends on whatever you can get the cheapest?
Old Sep 2, 2012 | 12:07 PM
  #34
Toadster's Avatar
2005 E55 AMG
i've heard BT is slower to update, but I have no experience testing one against the other...
Old Sep 2, 2012 | 12:38 PM
  #35
cij911's Avatar
one car at a time
Todd - Can you post data showing your IATs after a 3rd gear pull ? I saw that you posted that your IATs cruising are 10* above ambient which I have only ever seen with a split system (please let me know if you split the system). I am curious as I am testing different ways to keep IATs low.
FWIW, once I have driven my car hard, my non split system seems to keep IATs around 20 - 25* above ambient.
Old Sep 2, 2012 | 01:35 PM
  #36
Toadster's Avatar
2005 E55 AMG
https://mbworld.org/forums/5341027-post24.html
first two pulls in 3rd, last pull in 4th
Old Sep 2, 2012 | 02:00 PM
  #37
cij911's Avatar
one car at a time
there's a LOT of data logged - take a look
https://docs.google.com/open?id=0B0b...WVyM3I2S2VoejQ
For some reason I cannot view the data....downloaded, opened excel, tried to open the file importing CSV....garbage...sorry
Did you split your system ? Are you running the pump all the time (hard wired) ?
Old Sep 2, 2012 | 02:09 PM
  #38
Toadster's Avatar
2005 E55 AMG
you can download Scan XL from www.palmerperformance.com and export as CSV
but I converted for you
https://docs.google.com/spreadsheet/...zNvUzd1RDNoVkE
Old Sep 2, 2012 | 02:33 PM
  #39
cij911's Avatar
one car at a time
Thanks Toddd...reviewing now - looks good...
So you must have missed my questions :
(1) Did you split your system ?
(2) Are you running the h/e pump all the time (hard wired) ?
And what is the average & peak boost you are running ?
Old Sep 2, 2012 | 02:55 PM
  #40
Toadster's Avatar
2005 E55 AMG
1) it's just an upgraded H/E (using the FT-P HE now)
2) brand new Bosch 010 pump was installed last month - not sure if it's running all the time, but seems that it would be as it's been in the 90's 100s ambient around here
I have to check average/peak boost...
Old Sep 2, 2012 | 02:58 PM
  #41
cij911's Avatar
one car at a time
I believe the hard wiring of the pump is a great mod to do...mine is not done right now and only turns on when under WOT....running the pump all the time will definitely help keep temps down...splitting will help even more..
Old Sep 2, 2012 | 03:15 PM
  #42
Toadster's Avatar
2005 E55 AMG
I also have the -10C mod on the cooling fans... noisy, but really helps to keep the temps in check
Old Sep 10, 2012 | 11:09 PM
  #43
GregMB's Avatar
HA!
I finally got back from my Japan trip and figured out my PLX WiFi issue. Turns out that there is some sort of problem with the OBD-II splitter that I was using to share my OBD port with the PLX and the Valentine Saavy device.
As soon as I bypassed the splitter and plugged into the OBD port directly the connection worked perfectly.
I collected a quick log file tonight (need to get the Excel conveter to read it) and it looks like I need to learn more about configuring PIDs to get a complete data set in the future.
Anyway.... I'm happy at least that I'm able to play along on this thread and start comparing and sharing data with others here.
-G
Old Sep 11, 2012 | 09:58 AM
  #44
Toadster's Avatar
2005 E55 AMG
Originally Posted by GregMB
HA!
-G
good job! I too need to mess more with the PID stuff - just need more time!
Old Sep 11, 2012 | 10:32 AM
  #45
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
does any one know if you can monitor AFR with Dash Command?
Old Sep 11, 2012 | 11:11 AM
  #46
cij911's Avatar
one car at a time
You need a wideband O2 sensor installed in order to read AFRs. The O2 sensors installed in the car are narrowband and will not give you the level of data you need to tune the car.
Old Dec 26, 2012 | 01:43 AM
  #47
bnzuovr's Avatar
2004 W211 E55K, GL550
hey toad can u send me a link on ebay or were ever you bought your obdII wireless plug for your dash command app please and thanks. Or is there any other brand that will work with the dash command ?
Old Dec 26, 2012 | 03:04 AM
  #48
Toadster's Avatar
2005 E55 AMG
found mine on craiglist - used the allofcraigs.com site
Old Dec 26, 2012 | 11:39 AM
  #49
bnzuovr's Avatar
is there anything else compatible other then the kiwi?
Old Dec 26, 2012 | 11:01 PM
  #50
Toadster's Avatar
2005 E55 AMG
here's a link to the Dash Command Hardware compatibility list
http://www.palmerperformance.com/hardware/index.php
overall I'm pretty pleased for $60 for my Kiwi WiFi and $50 for the DC app
works on all of our vehicles
