Unique idea or something different, post it here
Old Aug 18, 2012 | 12:05 AM
jcjmw's Avatar
2005 E55 Wagon
I am always amazed at some of the ideas and mods members come up with. Like this J pipe (https://mbworld.org/forums/w211-amg/...er-delete.html). If you have a mod on your car that is out of the ordinary or not main stream, post it here please...and share with the rest of us.
Old Aug 18, 2012 | 08:52 AM
Forrest Gump 9's Avatar
shrimp boat
How's about running AC freon thru the IC?
Old Aug 18, 2012 | 09:02 AM
jcjmw's Avatar
2005 E55 Wagon
Can you post a pic of what you did or are you talking about the KC?
Old Aug 18, 2012 | 09:05 AM
shrimp boat
No, I have not do this to my car yet. I get the idea from the KC. Instead of running freon thru the KC to cool the water. why not just run the freon thru the ic directly?
Old Aug 18, 2012 | 11:08 AM
gsxrguy's Avatar
e55,cayenne turbo, supra, sti
I think the lack of thermal mass will be an issue
Old Aug 18, 2012 | 12:06 PM
RedBullJnky's Avatar
you to Hate
I have a Cobra HE mounted under my trunk. My split cooling runs from my trunk tank to supercharger to Eurocharged HE to Cobra HE then back to tank. The idea was to store cold water rather than hot water and expecting the single HE to cool it before it hits the SC. Now the hot water goes through both HEs and stores cooler water in the trunk tank.
At the track my IATs never went over 100. And on a 4th gear pull on the dyno to 180, the IATs never went over 110. Back to back pulls on the dyno and it only went to 120. It was 96 degrees on the dyno day.
Old Aug 18, 2012 | 12:08 PM
adianaty's Avatar
E55, CTS-V Wagon, Duc 1098R
Maybe an easier way to think about it is would you want our IC to be air to air since that is how well it would perform. It's actually a function of specific heat and the freon would be completely overwhelmed by the engine airflow. With the KC, you have alot of time to cool the water down. That benefit will go completely away if you went direct.
Old Aug 18, 2012 | 12:13 PM
Bramage's Avatar
F-250
I started a rear mount intercooler set up with dual fans, but never finished the project. I was using a Frozzen Boost core with dual 6" fans. It fed the trunk tank, although it was plumed to be able to go after the tank output. The though was I could try both ways, and see what worked better.
Meth injection works so good, I just sorta put the project on hold.
1/4 Mile (Famoso) Ambient Temp 72
