Airmatic issues: Part 3
2005 E55 AMG
Today I installed the new arnott rear airmatic bellows. Install on one side took nearly 2 hours...then I figured out that there were a lot of things that I removed that I didn't have to and the other side only took 45 minutes...lol.
Anyways...start the car up and allow the airbags to inflate before I drop the car and when I drop the car I was happy to see it hold it's normal height...woohoo...except...what is this sound? SHHHHHHHHHH..
The freaking new airbag is leaking. I thought it was from the fittings but it's not...the part where the fitting screws into is leaking. If I push downward with my finger it'll stop leaking. I can't believe it. Stranded again because a NEW part is leaking.![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
I'm so depressed right now...I definitely regret not going coil suspension at this moment, regardless of comfort.
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
03 E55 AMG, 06 Harley Road King Custom 06 Ram 2500 Cummins, 97 Firebird Race Car, 88 Cutlass Supreme
You'd think they'd test em out before shipping. Hopefully just a random mishap. You'll get a new one soon and be glad you did what you wanted and got the air suspension in the end.
What did/didn't you have to remove?
2005 E55 AMG
All that needed to be removed was the lower cover ( the one that covers the arm where the shock/bellow bolts on to ), the rear arm ( the one furthest to the back, just the outside bolt removed to get it loose ), and the shock absorber. That's it.
For the expansion reservoirs, you can't remove them with the subframe on so I just cut the hoses off and left them there. Cutting the hoses off completely emptied out the rear bellows when make them really soft and each to remove.
That's good. That's what I thought. I've removed a real spring that way. Put a jack under the control arm, loosen the control arm, loosen the shock bolts, but slowly lower the control arm to release the spring.
It will need an alignment afterwards but that only helps, not hurts.
It's just unfortunate that the new part has issues.
2005 E55 AMG
It's the part it's self where it screws in, not the fitting. Even after it has been removed it still leaks like crazy emptying the bag ( which shouldn't happen even after unplugging it from the air line ).
2005 E55 AMG
Well, looks like I'm in luck.
Today I took out the airspring again ( took 20 minutes this time ) and I decided to open the lid to see what's inside. The lid has 4 screws which were LOOSE. Upon opening it I see the solenoid and pull it out ( it's pushed down by the lid, not bolted nor glued ) and one of the o-rings in the solenoid was smashed due to improper placement ( I'm guessing someone was in a hurry when assembling it ). I replace the o-ring ( 4 in total, 3 small and 1 large ) and reinstall everything.
Woohooo....it works!!! No leaks. Took it out for a drive and the car feels great...perhaps firmer as they state in their website but it is barely noticeable. Feels in comfort mode as it did before in sport 1 mode.
I'm so happy.
I'm so happy.
2005 E55 AMG
I also removed the steering knuckle ball joint and replaced both lower control arms today with the sway bar link...on one side...lol. Took me 5 hours just for that one side, it was horrible. I don't ever think I've applied so much force in my life to remove and install the parts. I'm going to do the other side next week and I will NEVER do this again on this car. Insanely tough I tell you. I've rather rebuild my engine before changing ball joints again.
Arnott rears
GT-ER,
I just installed a set of Arnott rears in my 2003, E500 (W211).
Same with me, one side great, the other side whooosh. Leaking from under the top cover behind the electrical connector.
Arnott next day aired me a repalcement immediately with no questions. Unfortunately I didn't have the time to go through the internals and fix it my self.. I was already at wits end when the Bilstein OEM's failed after 30 days and less than 1000 miles.
Bilstein will not honor any warranty due to the installation, I took off the remote reseviour hose clamp for ease of installation.
I have Arnott fronts and rears and the ride is a bit stiffer, and I have a small chirp coming from the front that might be valving noises but I also replaced the upper control arms and lower ball joints as well as outer tie rods..basically I have a front end with ~2000milse on it, so some break in will tell.
Heck these Guam roads are the "break" in tool.
Arnott was so easy to install, has side to side interchangeability as well as ease of access to the air line installation. If they keep up their service standard then I am sold.
2005 E55 AMG
GT-ER,
After replacing all of the control arms in front and ball joints and getting a good alignment I can give better feedback.
First, it is considerably stiffer in the back. Feels much more connected and less "floaty" which I like. It's at the cost of some harshness that wasn't there before ( although still soft compared to steel spring suspension ).
The solenoids are also considerably louder than the oem ones...you could barely hear a faint "knock" with the oem ones but these click decently louder...the noise goes away after I stopped trying to hear it so it's not exactly bothersome either.
Other than that...my car feels fantastic now.
Originally the bilstiens failed completely. The pass side was probably the root cause as it just sat there and the selenoids clicked loudly and it would not pump up, the sideways cocked position caused the driver's side to buckle side ways and then deflate as well.
The pass. side Arnott leaked, but they are interchangeable side to side for the E500 W211 units. I removed the driver's side and installed the leaking unit and it leaked on both side (trouble shooting control unit suspicions)...I also aired it up and then removed the electrical connection and it still leaked.
2005 E55 AMG
Super Moderator
Damn....sorry to hear buddy. Coils as the next option...hopefully not too soon since you just bought these things!
