Weight savings, porting and engine wrenching.
PLATINUM SPONSOR
This duel line and Y inlet set up ,has been used on performance cars for a while and is really nothing new. Just new for our cars and another option I wanted to share, if you need a more stable fuel supply. I have the stock in tank fuel pump , that feeds a bosch 044 inline pump and I used 8an main line to my Y fitting. I am also using 715cc Injector dynamics injectors , as the 550CC will start to get near max duty cycle at 600 hp. Also needed the larger injectors to run the E85 , as you need about 28% more fuel. Going to E85 last year and just changing to 715cc injectors, I was pretty much dead on with my AFR. There are online calculators for fuel flow and how much HP you can make per line size and 5mm sucks for making a lot of power.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
I posted a few years back about our very small fuel rail inlet issue. This was the same time I posted how we needed larger injectors above 520 hp, injector info and how our fuel pressure goes from 80 psi to 62ish psi above 4500 rpm. I drilled my inlet from 5mm to 6mm at that time but that was just slight help.
Mine hunts slightly, but I am on 1000cc slugs, and I have a different line and pump setup than yours for my E85.
2005 E55 AMG
My car has 750's and my tach doesn't budge at idle, I do kind of feel a slight vibration in my steering wheel that oscilates which could maybe be due to the injectors, or due to my wobbling pulley...who knows...lol
PLATINUM SPONSOR
Check out the flow, engineering data and you can see how these injectors have reached near cult status, as they say.
http://www.injectordynamics.com/ID725.html#Dynamic Flow Characteristics - 4.14 Bar (60 psi)
IMO, we can run all the loops, big pumps and larger injectors we want but if you leave this 5mm ID fuel inlet,,, all that other work and flow is no help. Even the stock line is only 6mm ID, so limited again but helped by our high fuel pressure some. I had a picture showing this but cant find it at the moment.
GT-ER , may I ask what brand injector you are using?
If any of you decide to assemble the bottom end of one of these engines, the bearings are color coded and can use specific color/sizes for each jouranl. Nissan has done the same thing with thier engines and it is tricky to getting this right. Even if you take apart the botom end to clean and inspect, bearings need to go back where they came from. Color codes are marked on the crank and also on the block next to each journal, where the oil pan seals.
![](http://i991.photobucket.com/albums/af31/Vitabc/2012-08-01192238.jpg)
__________________
www.ultimatepd.com
www.ultimatepd.com
