Weird rattling noise in engine bay
Old Aug 29, 2012 | 11:18 PM
nizzle's Avatar
2014 AMG E63S, 2006 XK8 victory edition convertible, 2006 supercharged trailblazer SS, 2001 E430
Hey all. A few days ago, I was at a buddys house hanging out. When I went to leave, I started my car, and I heard a little ratting/"ting" or "pinging" like sound. The sound is pretty faint and sounds like rattling to me but my cousin says it sounds almost like a chirp or squeak to him. I swear it's coming from my EC 172 pulley but not sure why or even if that is where it is actually coming from. Again, the sound is not very loud at all but definitely audible. Another member in the forum described something similar with his car in this thread: https://mbworld.org/forums/c-class-w...ngine-bay.html. The car still runs and drives GREAT! I will try to make a vid of it as well asap. Please leave suggestions or comments on what you think this might be. Thanks
Old Aug 30, 2012 | 12:36 AM
nizzle's Avatar
bump
Old Aug 30, 2012 | 08:17 AM
moosejaw's Avatar
none
Could be a loose bearing in the idler pulley
Remove the SC belt to see if noise goes away
Old Aug 30, 2012 | 10:10 AM
nizzle's Avatar
Thanks for the response. Did that yesterday and noise still there
Old Aug 30, 2012 | 03:09 PM
ALLDATAdiy INFO's Avatar
Former Vendor of MBWorld
Mercedes
Alldatadiy.com has symptom related information that may help in your search for the answers to your issue. Good Luck on your search.
Old Aug 30, 2012 | 06:18 PM
nizzle's Avatar
bump
Old Sep 1, 2012 | 05:08 AM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
it will be the bearings going in one of the pulleys, you just need to find out which one and replace. most common is the idler, i had a similar noise only when cold and replace both idler pulleys and noise has not gone. Both pulleys had grease leaking from the bearings.
Old Sep 1, 2012 | 07:38 AM
GT-ER's Avatar
2005 E55 AMG
Remove all belts and check each pulley one by one. Turn the car on without any belts to see if the noise is still there.
Old Sep 7, 2012 | 08:51 PM
nizzle's Avatar
Thanks for the replies guys. I Will investigate these possibilities further next weekend.
Old Sep 8, 2012 | 07:59 PM
skinnes72's Avatar
2005 E55
Nizzle I have same issue. I have noticed it is not there upon startup for a few seconds. I have heard in the past that the clutch is engage for a few seconds upon starting (don't mind being corrected if wrong). With that the lack of rattle while engaged I believe my issue is a clutch or shim issue.
Any thoughts?
Old Sep 11, 2012 | 07:23 PM
nizzle's Avatar
I'm not sure. My small rattle is there all the time. Does not get louder or quieter under any certain circumstances. I believe heavily that it is an idler pulley but i will have to remove belts and start the engine in an attempt to narrow down the possibilities
Old Sep 12, 2012 | 12:14 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
i have a similar weird noise that sounds like its coming from dash.. thought it was instrument cluster so removed it and drove without it in and still had noise... shop put the car underload on a lift and says its header collector on heat sheild
https://mbworld.org/forums/w211-amg/...dash-area.html
