Woohoo, Passed Emissions with LTH
Old Aug 23, 2012 | 11:55 AM
novae500's Avatar
W211
Just got back from inspection station. Sort of nervous since i have MBH LTH and front cats deleted. But did install TTM o2 extenders when i got the headers installed back in Feb 2012 and no CEL codes since then. Also got a tune shortly after but rear 02s werent turned off, since i was not getting CEL. I know several of us on here had CEL after LTH were installed and rears turned off and hard to pass emissions.
Gas cap test :pass
Cat converter: pass
OBD Malf Ind Lamp: pass
OBD Diagnostic connector: pass
OBD Diagnostic trouble code: pass
VA does allow one failure and i passed all with no failures.
Old Aug 23, 2012 | 12:12 PM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Congrat!! I hope I pass emission this December when my tag expired. I still get the CEL with my LTH..
Old Aug 23, 2012 | 01:17 PM
RedBullJnky's Avatar
you to Hate
Congrats! I'm glad we don't have emissions in FL. Although if we did, it would probly take half the cars off the road. Lol
Old Aug 23, 2012 | 01:40 PM
novae500's Avatar
W211
What cel codes are you getting?? Are your rears turned off??? Did you ever get the ttm o2 extenders. They should have worked.
Rbj. My wife is from Orlando and some of the cars I see on the road shouldn't be. But others like ours w emission codes should be!! And I like how you can tint the frontwindshield too
Old Aug 23, 2012 | 01:56 PM
kompressede's Avatar
Sold - 05' E55
What tune do you have?
I went for my emisions inspection recently and it didn't pass. I'm getting a re-flash then attempting to go for another inspection. - PITA
Old Aug 23, 2012 | 02:43 PM
Toadster's Avatar
2005 E55 AMG
at least all your emissions blow out to sea, or back in with the occasional hurricane
Old Aug 23, 2012 | 02:46 PM
novae500's Avatar
W211
My tune was w/ OE TUNING(Jeremy). He did it remotely via obd port/laptop. Depending on where you are, you may allowed one failed for readiness and still pass emissions
Old Aug 23, 2012 | 03:47 PM
I'm getting two of P2198 CODES, 02 Sensor signal Stuck Rich Bank 2. Yes I got two extender stack on top of each other on each side and l'm still getting CEL. Apparently EC did not turn them off or they weren't able to with their equipments when they tune my ECU for the LTH.
Old Aug 23, 2012 | 03:48 PM
Sold - 05' E55
I have the OE Tune also, and I just received the cable, so I have to coordinate the remote tune adjustment.
I'm in NY and I had three fails - Rear o2 ls off, Rear o2 rs off, and fan off?
Next week we'll make another attempt, and If that doesn't work I have one more option to go with the o2's.
Old Jan 4, 2013 | 07:21 PM
markcali's Avatar
cls55
Did u resolve the problem ? And pass emissions please Lmk as I'm going with Oe tune and want to make sure I don't run into these same issues
Old Jan 4, 2013 | 07:32 PM
jay_55's Avatar
E55 AMG
i have to take my 10 year old beast through one of these this year and i also have long tube headers hope mine passes with flying colours as well.
Congrats on dodging a bullet
Old Jan 4, 2013 | 07:48 PM
Sold - 05' E55
I'm still not squared away. I haven't made it a priority right now (not driving while the roads are all crapped up). I have to get this butted up shortly because I want to use the car in the spring. I think I'm going with 02 extenders?
Old Jan 4, 2013 | 07:59 PM
markcali's Avatar
cls55
Okay are u running catless or u have secondary cats ?
Old Jan 4, 2013 | 08:23 PM
novae500's Avatar
W211
From what was explained to me by Bruce TTM and a few others, when you use the o2 extenders, there is less flow going pass the o2 sensors. If not extended, more of the o2 sensor is in the direct path of the flow and cause you to not pass/CEL come on. Hope you guys pass emissions when using the extenders.
The new design MBH headers have the o2 extenders built in.
Old Jan 4, 2013 | 08:31 PM
markcali's Avatar
cls55
Thank you for the info .. Novae which headers are u running ?
Old Jan 4, 2013 | 10:05 PM
Sold - 05' E55
No Cats, and I've talked to Bruce also, and I'll update as soon as I do the extenders.
Old Jan 5, 2013 | 11:32 AM
ziggityzen's Avatar
E55 AMG
Going to try out the extenders as well. CEL pops up only once in awhile.
Old Jan 5, 2013 | 12:01 PM
e55amgrocket's Avatar
Dirt Scooters
Gas cap test :pass
Cat converter: pass
We can't fail any of those things listed. It's the emissions readiness test that we can fail 1 part of. The test is for misfires, o2 sensors, catalytic converters, evap system and the egr. You can have 1 thing that's not ready (drive cycle isn't completed) but if you have a check engine light on you fail. I passed my last one with no cats on Q16 Now it's tagged where I don't need emissions
Old Jan 5, 2013 | 12:02 PM
VegasHruby's Avatar
2005 e55 amg w/mods, 2015 GMC diesel,2016 X5 Msport
The only reason for emissions is a revenue builder for the state. Another tax basically.
