found a local Dynojet!
Rating: Thread Rating: 3 votes, 5.00 average.
Old 08-24-2012, 12:15 AM
Toadster's Avatar
2005 E55 AMG
Lightbulb found a local Dynojet!
hopefully going to hit up a local Dynojet tomorrow...
3rd or 4th gear runs?
Old 08-24-2012, 12:34 AM
Bramage's Avatar
F-250
4th gear is 1:1
Typically, when comparing a 3rd gear pull to a 4th gear pull.. 4th reads higher (I dont know logic behind this, however I have some theories I just came up with)
Issue you may want to consider (Why some use 3rd)
  • 4th gear takes a long time to wind out, so if you are doing multiple runs, heat could be a bigger problem
  • If you have a speed limiter, it will kick in. Redline in 4th will be approx 180MPH
  • Some dyno operators don't like taking dyno to 180+
Overall, people use both. Good luck, and post up your chart
Old 08-24-2012, 12:46 AM
tbal's Avatar
Haters crazy
Testing them scoops? Should put down 100whp easy...
Old 08-24-2012, 12:59 AM
Toadster's Avatar
2005 E55 AMG
LOLz
Old 08-24-2012, 01:40 AM
E55Bullet's Avatar
2008 ML63 2009 SL63 2010 Alpha 7 GTR
Please tell us how much HP your "beast" puts down!
Old 08-24-2012, 05:52 AM
berti_00's Avatar
2016 Cls63s AMG
didnt you dyno recently teddy
Old 08-24-2012, 09:32 AM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Id do 3rd gear.. Interested to see what a tune and smaller s/c pulley will put down.. Im thinking the pulley is my next mod for sure
Old 08-24-2012, 10:04 AM
E55amg/FD3S's Avatar
03 e55
Take your car to Sac. Raceway which I believe is local to you and see what kind of power it "really" puts down!
Old 08-24-2012, 10:14 AM
Toadster's Avatar
2005 E55 AMG
yes, but the I/C pump was dying - IATs were 170-180, but still made 401 HP
Old 08-25-2012, 06:22 AM
Toadster's Avatar
2005 E55 AMG
I/C pump was working wonders today
446HP / 487 TQ
first two runs were IAT ~110-115; in 3rd gear
3rd run was in 4th gear, IAT at 122 - ran the dyno up to 202MPH!
so - corrected for 18% loss - that's 544HP and 594 ft-lbs!?!
Old 08-25-2012, 07:39 AM
FinanceMike's Avatar
CLS55
That's with the smaller SC pulley? Those look like ECU tune only numbers.
Old 08-25-2012, 07:42 AM
GT-ER's Avatar
2005 E55 AMG
That is interesting....my car made 430whp bone stock.
Old 08-25-2012, 09:23 AM
CLS55
That's why I was asking. Stock 55k on dynojets that I've seen range from 410-420hp stock with around 450tq. Tunes with no pulley resulted in 440-450hp and 475-485 tq.
Old 08-25-2012, 09:36 AM
Bramage's Avatar
F-250
And Dyno numbers mean squat... BUT, if the AFR chart is available, it will give you an indication as to where the tune is.
Is this the smaller upper, or lower pulley?
Pulls look good, and you should be happy!
Old 08-25-2012, 10:14 AM
cij911's Avatar
one car at a time
Todd - Are the IATs you listed the peak numbers or where they started ? The IATs seem low given ~87 degrees ambient temperature, unless they are the starting point. I'd be curious to see your IATs at the end of the pull.
Old 08-25-2012, 12:19 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Well now that you found a dyno, stick with it to ascertain mods/gains. Jumping dynos is hardly a good comparison down the road. Best of luck and looking forward to your monster gains.
Old 08-25-2012, 12:25 PM
AMGPilot's Avatar
2004 E55
Those TTM scoops really helped with your power there......
Old 08-25-2012, 12:37 PM
pearlpower's Avatar
They might be installed backwards. seriously, I bought mine for the looks only.
Old 08-25-2012, 05:00 PM
Toadster's Avatar
2005 E55 AMG
yes that's with the S/C pulley + box tune
so considering 18% powertrain loss - your car made 524 at the crank from factory! (430RWHP / .82 = 524.39HP) that's pretty awesome
I logged using my Kiwi WiFi during the runs - there's a TON of data, so I need to run through that. This was at a local UTI school and there were SO many students hovering around the car that we forgot to log AFR on the DynoJet - so hopefully I have the data correct in my logging
this is just the smaller S/C pulley - I'm starting to think that I DO have belt slip as I drove it the night before in Dyno mode and had some interesting squealing going on under the hood...
I'm happy, was shooting for 450 at the wheels - got really close - the last Dyno day, all I got only 401 (but different Dyno and IATs were **** that day) maybe changing the intake tubes for Pythons or the newer FT-P tubes would give a little more and if I tweak the exhaust more than stock it should hit no problem.
I watched/logged IATs during the runs - honestly it didn't jump into the 130's until after the 3rd Dyno - they had a nice wind tunnel setup with fresh air pumping into the small room and exhausting out the air out the back. I was very impressed with their setup!
they won't help on the dyno
Old 08-25-2012, 05:32 PM
03 e55
Track #'s > Dyno #'s. Like I said before take it to Sac. Raceway.
Old 08-25-2012, 05:43 PM
Toadster's Avatar
2005 E55 AMG
I may do that - the President of the school invited me to their track day tomorrow
Old 08-25-2012, 05:46 PM
Bramage's Avatar
F-250
My God.. Ive been trying to get to a track for a year. DO IT!!
Sac can be very fast. E55 record that stood for 2 years was run there (Bassn-07)
Old 08-25-2012, 05:49 PM
Toadster's Avatar
2005 E55 AMG
nice! I'm hardly a 10.7 car though
Old 08-25-2012, 06:20 PM
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
They finally fixed their trap speed calibration, so the runs don't trap as high any more. Nonetheless still a blast!
Old 08-25-2012, 06:32 PM
AMGPilot's Avatar
2004 E55
They also won't help on the road
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: found a local Dynojet!
