Lowering FTW!
Old 08-27-2012, 08:53 AM
djrabbi's Avatar
CLS550 4Matic, C43, E350, ML350
Lowering FTW!
So went to re-do my calipers and took off my wheels and found this! All 4 tires with same problem....Thank god I had another set of brand new pirelli tires laying around. Def. ordering toe links and camber arms. Anyone have suggestions on which ones are good?
Old 08-27-2012, 09:11 AM
novae500's Avatar
W211
looking low comes with a price of tires!!! Thats why i dont want my w211s as low as i used to have my honda/vw. One finger gap is good enough for me on my w211s.
Old 08-27-2012, 09:13 AM
djrabbi's Avatar
Any good places for alignment in NoVA?
Old 08-27-2012, 09:23 AM
novae500's Avatar
W211
http://www.ptuning.com/html/services.cfm in manassas
Funktion auto in Sterling, but more expensive
mercedes of chantilly.
Old 08-27-2012, 09:29 AM
cij911's Avatar
one car at a time
When you slam the car, not only are your alignment settings screwed up (which you know and can be addressed with the parts you are asking about), but equally important, you are ruining the handling of the car by significantly reducing the suspension travel. Lowering the car a little bit is probably ok, but anything severe like I see on these boards is no good.
In terms of parts : KMAC and MB Arts seem to be the two leading contenders....I like KMAC.
Old 08-27-2012, 09:30 AM
djrabbi's Avatar
I am running stock height now hehe
Old 08-27-2012, 11:22 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
[QUOTE=djrabbi;5335705]So went to re-do my calipers and took off my wheels and found this! All 4 tires with same problem....Thank god I had another set of brand new pirelli tires laying around. Def. ordering toe links and camber arms. Anyone have suggestions on which ones are good?
Evo and KMAC are possible choices. If you lower the car, you must have the geometry reset properly.
Old 08-27-2012, 11:39 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
Get a proper alignment while at drive height and you'll be fine. you're not THAT low - im pretty certain your toe ate your tires alive.
Old 08-27-2012, 12:19 PM
GunMoto's Avatar
EG8 | E46 | W211
+1
Old 08-27-2012, 01:07 PM
baldmike73's Avatar
'14 E63s Estate, '21 RR P525, '22 GMC 2500, '23 G63
I had the same thing at stock - even had one tire shred on the inside while on the fwy in the fast lane - luckily i had a buck knife to cut the overage on there - limped to the tire shop!
Old 08-27-2012, 01:32 PM
moosejaw's Avatar
none
get together with BBBS and compare notes
Old 08-27-2012, 01:58 PM
Infamous 1's Avatar
2004 E55 AMG
Ptuning in Manassas or Autothority in Chantilly
Old 08-27-2012, 02:51 PM
SilverStrk's Avatar
05 E55, 07 ML500
Had the same thing happen with the stock Conti's, blew out front left on the freeway.. Took the car to Discount Tire and found the others that were about to go as well, long story short, I *****ed and they sent them back to Conti as defective and replaced all for free with PS2's..
Old 08-27-2012, 02:54 PM
djrabbi's Avatar
Good info guys. I am getting my wheels balanced today since the places that mounted the tires apparently didn't so my wheels shake a bit after 60MPH. I will get alignment at one of the places you guys mentioned maybe next week and get dyno done too
I was pretty low (too me atleast) I will be leaving 1 finger gap all around, think I would need new camber arms and links or OEM with alignment should be fine?
Old 08-27-2012, 04:52 PM
cij911's Avatar
one car at a time
I checked my alignment today (I am not very low at all) :
Camber was ~-2* Front & Rear
Toe was 0.08 Left & Right ; Rear was ~0.2 left & right (IIRC) - rear was out of spec
So I could definitely benefit from a KMAC setup front & rear as I could adjust camber and toe (in rear)...I think -1* camber is about as much as one needs for a street car and I am guessing that the extra 1.5 degrees + toe in the rear is really eating up tires.
Old 08-27-2012, 04:59 PM
Alps's Avatar
E63s s213 2019 ,SOLD E63 Weistec, E55, C36
get alignment done and get them to put in the MB alignment bolts, that will help alot.
Old 08-27-2012, 06:42 PM
GregMB's Avatar
I would love to see a thread like this (excessive tire wear complaint) where the OP goes to an alignment shop and gets the "before" numbers recorded by the alignment shop (the ones that ate the tires!) and then an "after" alignment report showing how the car ended up after adding toe links, camber arms, alignment, etc.
That would be a huge help if anyone feels like doing it.
-G
Old 08-27-2012, 06:55 PM
timeToy's Avatar
'08 E63 Wagon
I have the K-Mac bushing AND MB Arts toe links to be able to maintain proper alignment geometry while (slightly) STAR lowered.
The K Mac bushing alone will give you front Camber and Toe control, as well as rear Camber control, unfortunately our car are too powerful and the rear Toe bushing can't hold the torque applied to it under hard acceleration and will come undone, which is NOT a good thing, trust me! That's why I had to use stock 'toe' busing and the MB art rear toe links, now the wheel stay in place and alignment is in spec and stays that way.
A less expensive option might be to use Mercedes adjustable bolts, but the range of settings is very limited.
Old 08-27-2012, 07:27 PM
rchase's Avatar
2004 E55 (sold) 2012 E350 4M
Im curious what settings you used to slightly lower the car? All that i see on the forums is the standard 3.5 and -1.1..... and i dont like how low it is with that setting and my 20 inch wheels
Old 08-27-2012, 09:08 PM
GregMB's Avatar
I would like to suggest that for lowered settings it might be helpful to describe in terms of fender lip height from the ground (front & rear). This would be an easy number for everyone to collect and might simplify discussions.
-G
Old 08-27-2012, 09:57 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
I thought I read somewhere that this had been solved with a newer design. I'm ready to pull the trigger on some KMAC rears, but that sucks if I can't use the toe bushings.
Old 08-27-2012, 10:32 PM
djrabbi's Avatar
You mean the settings in SDS right?
Old 08-28-2012, 05:59 AM
timeToy's Avatar
'08 E63 Wagon
My installer (ACG in San Diego) was able to dial in the exact amount of drop I wanted (to a point, front wheels independently and rear axle), I think theses values are for example.
Old 08-28-2012, 03:25 PM
Nino S's Avatar
2005 E55 AMG
I am the service manager at Lustine Toyota in Woodbridge if you want to get one done. I have a dedicated alignment tech that does my car every 90 days and I have great tire wear, but also do not have a ELM installed. I can do an alignment for any of my fellow E55 owners for $60. Just let me know!
Old 08-28-2012, 03:36 PM
DGSU4EA70's Avatar
2005 E55 (FST N OC)
To OP,
I read awhile back (because I had the same problem with my rear tires) that depending on which mode (C/S/M) you drive in can affect tread wear immensely. It was said (not sure by who) that different drive modes change the toe/camber settings. Can anyone validate this??
DG
Quick Reply: Lowering FTW!
