Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
#401
06 E55 AMG, 13 C63 AMG
I have the EC 82mm throttle body. It does not fit the 82mm inlet like it should so I had to modify it a tad. I also have to lengthen the harness to the throttle valve so it will come back off in the morning to give me working room.
A couple of other minor tweaks and I will be happy with everything.
I have the MBH Headers, MBH mid pipe and the stock exhaust from the resonator back.
G
#406
That hose gets connected to a nipple at the air filter.
G
G
It will feel like a monster since you haven't driven your car in 6 months, you will be very happy with the results.
#410
Once I got the stock pump replaced the supercharger stopped disengaging. When I was on the road course beating the snot out of it on a very hot day the supercharger did not ever disengage so it seems the stock HE was keeping up, well until the supercharger seized up.
I am running the stock cooling system configuration. Weistec did say they were going to send the the procedure to doing the split cooling system, but it is not in the box.
G
#412
For now run it the way it is and in the next few months do the heat exchanger and split cooling so you can feel the difference afterwards, its gonna feel like night and day.
#413
I signed up for that dyno day EC did here in Beltsville MD. Jerry flew out and I was supposed to get my car custom dyno tuned by him. Did not work out well.
I rushed and got the EC Stage 3 installed with the I think 550cc injectors.
Jerry kept running into problems on the dyno. Kept getting cylinder 8 miss fires. So it got pulled off the dyno. Turned out to be a connector on the injectors that had a loose contact. Never finished tuning it there were cars lined up deep.
Went to the track the next morning for the event there and I was running my wideband on it and it was chugging richer than 9:1 AFR, but still ran a 12.1 1/4.
Never did get the tune squared away and never got back on the dyno. Then the supercharger seized up.
I can tell you wen it was running 11:1 AFR it was very ballsy, but needed a couple more degrees of timing, but was doing that random lean out thing that was a matter of great concern.
G
#414
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
G- Considering the experience you've had thus far modding the car, you deserve this part to go well.
Since you're in the business off S/C kits, will be very interested to hear your opinion of the overall package.
#424
I don't think anything got sucked into the rotors. The inlet is on the other end. Looks to me that one of the bearings failed and that allowed the rotors to collide and self destruct.
86,000 miles stock, no problem. Less than 1000 miles with the 180 pulley I get to buy a new supercharger.....
G
G
#425
Dirt Scooters
Couldn't imagine how hot that supercharger was on a 95 degree day on a road course with stock cooling and a 180mm pulley. Any sign on a oil leak? I've seen a few have leaks in the past.
