Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
#552
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
I was just wondering in case anyone cares/can answer. Months and months ago I purchased every possible power upgrade from Eurocharged (Stage 3 Plus with TCU tune)
Renntech Carbon Fiber air boxes, etc...
I'm well aware that the Weistec Engineering M113K Supercharger system is around $8,600 (plus installation, tuning etc...)
What I was wondering is....would most of the Eurocharged equipment have to be taken/sold/replaced with many Weistec components? Or could they all would harmoniously and produce a monster? Hypothetically speaking all my mods + the new superhcarger, on a 55K CL motor, would that = crazy fast?
Thank you
Thank you
#553
06 E55 AMG, 13 C63 AMG
I had the EC Stage 3 on my car before I upgraded to the Weistec supercharger.
The only part I reused was the 82mm throttle valve. Everything else was replaced or rendered obsolete.
You will also likely need your original crank pulley to be reinstalled.
The only other parts that remained were the headers and mid pipe that I had on there.
G
G
#555
In the stock configuration the clutch engagement was not a big deal at all. When you start winding the thing up, like with the 180mm crank pulley I had, it is a bit much. When people road with me it caused them some concern when the whole vehicle shuddered.
The new system is very smooth and very powerful.
G
G
#556
G
G
So would you recommend parting out (nearly) all the EC upgrades for the Weistec?
#557
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
You will still be able to use everything on the exhaust side. Bypass valve may be used from the OEM SC
Cooling system will be required for both setups.
#558
1 Post
2004 E55K AMG Wagon
G
G
I thought about that when looking at the photo's, why did you have to swap back to a standard crank pulley or was it personal choice?
#559
You will have to talk to Weistec to see if they have a pulley combination that will work with your crank pulley size.
They do have the correct combination for the stock crank pulley.
Yes, I wanted to go back to stock size anyway. There just seems to be to many issues overall with the different aftermarket ones.
G
G
#561
I left you a PM too
#565
05 White Pano E55, Cadillac CTS-V
Yeah, that video doesn't make things look to good when the E55 got stomped by an M3 said to be making under 600whp on a dyno jet and low 500s on other dynos. I hope they just had traction issues and traction control killing the power allowing M3 to work them.
#571
PLATINUM SPONSOR
With the New TB inlet location, looks like you could go 90 or 102mm if you wanted.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#573
E55 AMG
http://www.youtube.com/watch?v=jgOr0d8M9Vw
Ouch!
