Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
Rating: Thread Rating: 13 votes, 4.69 average.
Old 09-15-2012, 11:16 AM
  #176
GT-ER's Avatar
2005 E55 AMG
Originally Posted by cij911
Sorry but I respectfully disagree - getting cold air would be more beneficial than a short intake snout / design. Once the hood is closed the temperature around the engine is 160* +, then you add compression heat, and then try to cool the mix to avoid detonation. Using an average ambient temperature of ~ 80* where I live, would mean increasing the cooling system requirements by another 80* (a large amount). I am guessing they just could not find an easy path to the front
You can disagree all you want, but you aren't taking into consideration the pumping losses of a restrictive intake. I've done the tests myself and in my Pontiac Grand Prix I made more power with a filter straight on the TB( dynoed with the hood closed ) than I did with a 3" intake into the fender. I later modified the fender opening and fit a 4" pipe and that's when the intake made more power than a filter straight on the TB.
I later did the same on my 1.8T GTI and I could never get an intake that made more power than a filter directly on the MAF and straight into the the turbo inlet. Granted, I could never fit a pipe larger than 3". Not only that, but I measured IAT's with these setups on this car and the open filter did not raise IAT's AT ALL...I could not measure a single degree difference between a CAT and a HAI. That's an efficient intercooler doing it's job.
On my E55 I saw the oposite, the open TB made less power then the oem airbox. The oem airbox isn't half bad though especially when modified and the oem intercooler is already at it's wits even with cool intake air and probably can't handle hotter air.
Now, the Weistec setup? Try pumping 700whp worth of airflow through a 3" pipe that'll be at least 3 feet long. The open cone will make a lot of sense after you do. Perhaps those who buy it can make a large intake that will help feed it properly. Either way, I guess we'll find out.
FWIW, if you know how to read compressor maps, you know that intake restriction affects how you apply a map to an engine.
Old 09-15-2012, 11:38 AM
  #177
cij911's Avatar
one car at a time
You are correct I am not taking into consideration the pumping loss of a restrictive intake, as I would not recommend installing a restrictive intake. The example you provide with your Pontiac, proved that on your application the the 4" was better than the 3", which would make sense for a highly modified car. The turbo scenario is slightly different, but I have a lot of data (and it has been discussed ad nauseum on other sites) that still shows a properly designed CAI is better than just an open filter, especially in low speed courses or events (at high speeds the difference can be negligible).
Old 09-15-2012, 11:59 AM
  #178
GT-ER's Avatar
2005 E55 AMG
A properly designed CAI is definitely better than an open cone, I never said otherwise. The problem is making a properly designed CAI on the Weistec setup. I'm not sure how possible it is without modifying a few things underhood, such as the radiator.
Old 09-15-2012, 12:38 PM
  #179
chawkins2001's Avatar
2006 E55 AMG
600rwhp through this 3.0 Weistec is PLENTY on the street for a E55. One of the holy grails in terms of the fastest daily driven street cars, with a/c, reliability and cheaper enough for the common folk, is the twin screw terminator cobras. They make 600rwhp easily on pump gas around 18lbs, and will last for a very long time if taken care of with a solid tune.
Now put that same power level into a E55, and you too should have an easy pump gas 600rwhp car at less boost, I am thinking around 15lbs. I will tell you this, very rarely do twin screw cobras lose on the street, they have a damn good reputation. But I saw first hand when I was up at Timmayfest, a 600rwhp cobra get *** raped by a 530rwhp e55. They went at it twice and both times, the e55 from a 30mph role jumped out 3 cars from the hit and held it. The mustang could not real it in. For those of us that were there, it was an E55 on this board, and his power level I believe is 530/580 on a dynojet. He can reveal himself on here if he wants. Three of us on this forum where there to see it first hand.
Now imagine adding 70rwhp more with the Weistec Part of the problem is, if you start shooting for 650rwhp or even 700rwhp, you will never hook up, and will probably get your *** handed to you by lesser cars. I am not saying the E55 is a lesser car than a twin screw cobra, but that guy had 315 Nitto Drags, and the e55 was on 20" street tires, poor cobra could still not hook up, where as the beast squatted and hole shotted..... There comes a point when to much power is useless.
Old 09-15-2012, 12:50 PM
  #180
GT-ER's Avatar
2005 E55 AMG
You'll hook up. Do 80mph rolls in 3rd.
Old 09-15-2012, 01:05 PM
  #181
marc.l's Avatar
2003 E55 estate
How hard would it be to switch to twin throttle bodies , like the 63 ? Then it could draw air in like the new brabus twin turbos , through hood vents .
Old 09-15-2012, 01:07 PM
  #182
blackbenzz's Avatar
haters crazy
Roll around on real drag radials and you should be ok. I did it with over 600whp. Actually there's a vid from a few years ago of my car running a cobra. He was shocked
Old 09-15-2012, 01:18 PM
  #183
novae500's Avatar
W211
I remember that video at ocean city w tha cobra at night.
Old 09-15-2012, 01:41 PM
  #184
GregMB's Avatar
Holy crap!
Did I just read that correctly? I feel all dizzy inside..... I think someone is logged in to Craig's account and is posting weird stuff.
-G
Old 09-15-2012, 01:57 PM
  #185
urbamworm's Avatar
05 White Pano E55, Cadillac CTS-V
I have raced a 3.4 Whipple Cobra at the track before, he said he had 700 or 750whp if I remember right with a built engine, etc. He was on some worn out drag radials and I was on my regular street tires on 19s. I had my GoPro stuck to the side of my car facing backward for the heck of it which would have been awesome since I ended up beating him, but they made me take it off saying they don't allow suction cup mounts at that track so didn't get it on video.
He was all over the track, I was watching him in my rearview/sideview mirror almost the whole track as he fishtailed all over the place trying to beat me lol. He trapped like 126 if I remember right but ran a high 12.
I would like to see that video mentioned above if someone can find it.
Old 09-15-2012, 02:10 PM
  #186
Hulk's Avatar
A Merc
I think I know who that is, his power curve never drops off and obviously that's a big factor, he has his cooling tuned in perfectly
Old 09-15-2012, 03:40 PM
  #187
DVC
DVC's Avatar
'06 E55 AMG
Damn. Now if only the Merc could sound as good.
Old 09-15-2012, 04:16 PM
  #188
blackbenzz's Avatar
haters crazy
Yup rolling with my friends at muscle car weekend
It's not much, just a quick hit but it was first gear on Dr and it hooked fine. I drive around on Dr alot and it always hooked, maybe my suspension was set up right. I didn't try from a dead stop though. It was years ago so I was running lower boost than when it let go. Still a mid 10s car back then. It's around 2:50 into the video
Old 09-15-2012, 07:53 PM
  #189
e55amgrocket's Avatar
Dirt Scooters
I drove around on drag radials (Hoosiers) for about 250 miles before the crank pulley killed it and it would hook up pretty well honestly. It would spin in 1st but you could keep it flat footed and it would recover fast and that was around 620rwhp. I sprayed the 50 shot on a 60-130 run starting at 45mph 2nd gear and it dead hooked so I think traction will be ok. On street tires I could spin at 70mph easily just rolling into it and the traction light would blink past 100 so it was fighting for grip the whole time. That's also with the Quaife diff too
Old 09-23-2012, 07:36 PM
  #190
oilbim's Avatar
s55
Dear support.
I would like to know, when you will have AMG 55 5.5L M113K M113K Supercharger System in stock.
I would like to receive notifucation when it will be availbale in your stock.
Thank's in advance.
Regards.
Your customer
Old 09-23-2012, 08:20 PM
  #191
marc.l's Avatar
2003 E55 estate
And ps
Any chance of any dyno numbers ?
Old 09-23-2012, 09:12 PM
  #192
Shifter's Avatar
E55, SL63, ML550
I think they have been busy on the 63 supercharger kits adding more options and put this aside for now? I mean geez it's been a while now with no new info.
Old 09-24-2012, 12:23 AM
  #193
urbamworm's Avatar
Yeah, I went on their site and "pretend" ordered the stage 3 kit for the 63, go figure I was able to do it but then went to 55k and it was "out of stock." They just really hate us I suppose.
Old 09-24-2012, 01:06 AM
  #194
PACougar's Avatar
1000Hp Diesel Trucks, 2019 E63s
Nothing like announcing a product you haven't actually finished. By the way did I mention I finished my whipple kit and it's for sale but it's out of stock right now
Old 09-24-2012, 05:06 AM
  #195
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I've never been on the rollers and I only run street tires, but I know that 1st and 2nd are useless if you're not judicious with your right foot (we all know that). On a cool day with IAT around 55F, I can light up the ESP at 100 MPH. So I've been done looking for more HP. Just enjoying a great cruiser that is faster than 98% anything else around and has the matching handling qualities (after a few refinements).
Old 09-24-2012, 11:21 AM
  #196
Nino S's Avatar
2005 E55 AMG
have they shipped out ONE of these blowers yet??? hmmmmmm
Old 09-29-2012, 08:43 PM
  #197
rkeller411's Avatar
2006 cls55
I'm in when the comes out
This is one kit worth waiting for. The air intake can be solved later. The cone will work for start
Old 09-29-2012, 09:05 PM
  #198
jcjmw's Avatar
2005 E55 Wagon
These vendors need a lesson in marketing.
Old 10-01-2012, 12:28 PM
  #199
marc.l's Avatar
2003 E55 estate
Should be done just in time for the release of the new w269 twin electric hydrogen powered cars ......
I will soon have my chassis ready but no available uprated supercharger
Old 10-01-2012, 01:21 PM
  #200
MBworld Guru
OCKlasse's Avatar
04 CL55, 05 E500S4, 15 BMW i3 REx
After this thread started, I posted my insight into this company:
Originally Posted by OCKlasse
Praise to Weistec for this kit.
I have to say though, I am a little skeptical of their stellar reputation. I referred a contact to Weistec for a tune on his M157 because of the professionalism and quality they (appear to) exude. He was planning on originally going with a Renntech tune before I more or less convinced him to check out Weistec's tune. Long story short, it was a very unsatisfying experience for him. It made me look bad for referring him to Weistec because of how poorly he was treated and the damage done.
My point is, before you all spend a lot of money for this kit, see it in person, and maybe get to know them a little bit better. I'm not saying that everyone has poor experiences with them, and I'm sure it must be a rarity, but I can only speak from his experience, and because of that, I don't think I could do business with them.
Weistec then contacted him and told him that until I deleted my original post, they would not fix his car. He then contact me and told me to delete the post, and I had it deleted out of respect to his wishes.
After speaking with a friend who is a lawyer, I discovered that this sort of blackmail is in fact illegal. You sure you want to be giving these guys your money?
Weistec: Why don't you contact me directly this time if you're going to muscle down people...
You have already rated this thread Rating: Thread Rating: 13 votes, 4.69 average.
Quick Reply: Official Weistec M113K 3.0L Supercharger, PICTURES INSIDE!!!
