fyi: arnott FINALLY sells rear airmatics
i don't frequent much anymore but a quick search tells me there hasn't been any talk of this lately...but we all know how well the search function works so forgive me if this is old news to you guys.
Im hoping its possible to pull it out through the subframe somehow without disconnecting anything. I did not look that hard at it when i installed the arnotts just cut the pipe and installed them called it good.
But i would like to remove the reservoir?
Left my car sitting for 5 days this week and the ***** was slammed in the rear. Still raises.
My neighbor's E320 down the street has done this for years. I'm not too worried yet.
Weather it would be an actual problem im not 100% sure but id rather they was gone. I might have a look at it today and see if its possible.
Modifications like coilovers over here need an "engineers" cert to say the car is roadworthy. It a pain in the ***.
As soon as they see that anodised red bit of the bottom of the air spring i can see them making my life difficult over that even.
....it was a while ago and I might have had other items in my cart?
Sounds like that is for one air spring - they retail for US$451.96.
If replacing an O.E. unit with an Arnott Air Spring you MUST replace both rear air springs at the same time.
Replacing just one O.E. spring with the Arnott designed air spring may result in a slight difference in heights between the O.E. side and new air spring side. This is due to the vehicle’s ride height sensor reading different pressures in the new and O.E. springs and automatically making adjustments for that. This does not occur if you replace both sides at once.
Our installation manual and video both include the procedure for the complete disassembly which is needed to remove the air reservoirs.
Install Video:
Installation Manual: https://www.arnottindustries.com/fil...963&Size=SMALL
https://www.arnottindustries.com/part_MERCEDES-BENZ_yid18_pid134_gid963.html
They were available as pairs as recently as December 2013 so I can see where the confusion may have occurred.
Overall a good solid product though.
