New PB at local Raceway last night. Thoughts?
Subscribe
Sep 22, 2012 | 05:24 PM
Finally got her to goo
Thanks to Eurocharged for the tuning, and Jawanda Motosports
11.65@123.16 1.74 60'
If I can get 60' down to 1.6x could I break 11.40?
Reply 0
Sep 22, 2012 | 05:27 PM
What was the weather, DA, we're you on DRs?
Reply 0
Sep 22, 2012 | 05:38 PM
Not bad.. Motorkas has basically the same set up as you (he had 168 pulley, Kleemann headers and tune) and his best was somewhere around a 11.2, so you might have some room for improvement.. With a bigger TB you would have a very low 11 second car!
Reply 0
Sep 22, 2012 | 06:04 PM
man thats mph for a 10.9
Reply 0
Sep 22, 2012 | 06:26 PM
Awesome,
Reply 0
Sep 22, 2012 | 06:31 PM
Quote: Not bad.. Motorkas has basically the same set up as you (he had 168 pulley, Kleemann headers and tune) and his best was somewhere around a 11.2, so you might have some room for improvement.. With a bigger TB you would have a very low 11 second car!
Was so close to grabbing a 80mm kit but decided to wait on a 82mm...
Yes on Toyo Drag radials
Reply 0
Sep 22, 2012 | 06:32 PM
Quote: What was the weather, DA, we're you on DRs?
Da not sure, weather 14degrees celcius.
Reply 0
Sep 22, 2012 | 06:41 PM
That's good weather bro.. Get the 82mm
Reply 0
Explore
Sep 22, 2012 | 07:08 PM
That's a nice trap. Car is definitely making power.
Reply 0
Sep 22, 2012 | 07:13 PM
Awesome T, congrats!
Reply 0
Sep 22, 2012 | 07:24 PM
Congrats, I'm sold on the 168mm kleeman pulley even more now being I already have there headers and tune. Amazing trap 123 haulin a $ $
Reply 0
Sep 22, 2012 | 09:10 PM
If you cut a 1.60 then yea you have a shot at breaking 11.40
Reply 0
Sep 22, 2012 | 10:32 PM
good job Tony!!!
Reply 0
Sep 22, 2012 | 10:34 PM
i need those Washington temps here in Alabama!!
Reply 0
Sep 22, 2012 | 10:37 PM
By next month you should be in the 50s at night
Reply 0
Sep 23, 2012 | 09:41 AM
Stout run!
The general rule is every 1/10 off your 60ft reduces your ET by 2/10s. So, yes, you could make it.
Reply 0
Sep 23, 2012 | 09:43 AM
Nice run, awesome trap with a 168 pulley too. Need one of those instead of the fire breather 178 I have. Well, or a stock one and Weistec up top if they quit fooling around.
Reply 0
Sep 23, 2012 | 01:26 PM
Nice run and MPH! Shave 1/10 off your 60ft and that usually will net you 2/10 off your final ET. If you can run at another 1000 feet lower DA, could be worth another 1/10 off.
Did you take the DA for the run?
Reply 0
Sep 23, 2012 | 03:11 PM
Thanks for the feedback guys
I didnt check DA... should have I think part of my launching problem is the ****ty toyo drag radials... suggestions for a better 17" drag radial? Leaning towards some M/T's...
Reply 0
Sep 23, 2012 | 03:15 PM
MT are good for some, btw how did you launch?
Reply 0
Sep 23, 2012 | 05:42 PM
http://www.dragtimes.com/da-density-...calculator.php
If you fill out all of the info, you can find out what the DA was during your runs.
Reply 0
Sep 26, 2012 | 04:15 AM
Quote: MT are good for some, btw how did you launch?
brake and hold accel, than stomp from s1... car doesnt seem to hold well over 2k rpm...
Reply 0
Subscribe
Currently Active Users (1)
